Electrical Problems!! Help!!!!
Old Nov 12, 2007 | 10:01 PM
rva33145's Avatar
rva33145
Default Electrical Problems!! Help!!!!
Ok here we go. I will try to describe everything as best as possible. Car is a 1999 C5 Coupe with 64,500 miles and auto trans. Car has Column Lock Bypass installed. Started off by switching from MPH to KPH on it's own. Switches back and forth randomly by it self. At times the switch will not work to switch back to MPH. Sometimes it will. I installed the CLB myself amd never got any "service column lock" messages. Recently started getting service column lock message as well as "pull key and wait 10 sec." message. When I pull the key and wait the message to pull key goes away when I re-insert it. However when I start car and put it in gear to drive away it sometimes shuts off. Car is all original except for SLP loudmouth exhaust. No clue where to even start. Some suggest dash cluster others suggest body control module. I know there is a vast amount of knowledge on here about these cars and your help would greatly be appreciated.
Old Nov 12, 2007 | 10:04 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sounds like the CLB has failed. Some were good quality and I hear that others have failed on people. First you should check the state of your battery which is more likely to cause issues.
Old Nov 12, 2007 | 10:35 PM
rva33145's Avatar
rva33145
Thanks. Will do. ANy other suggestions?
Old Nov 13, 2007 | 11:49 PM
rva33145's Avatar
rva33145
I know there has to be some other input out there. HELP!!!!!
Old Nov 14, 2007 | 08:28 AM
Plasticfan's Avatar
Plasticfan
Like to help you buddy but that is beyond my level of expertise. PM Bill Curlee, if he can't help no one can.
Old Nov 14, 2007 | 08:41 AM
Bugaboo's Avatar
Bugaboo
Yep, get ahold of Bill. Sounds like a ground problem somewhere.
Old Nov 16, 2007 | 11:45 PM
rva33145's Avatar
rva33145
Can anybody else please provide me some insight on the possible causes of this problem.
Old Nov 22, 2007 | 09:34 PM
rva33145's Avatar
rva33145
OK. Cleaned ground contacts and replaced the battery with a new Optima. Still having the display switch from MPH to KPH back and forth on it's own. Also still getting the "service column lock" on the display even though the CLB is installed on the car. Does anyone think I may need to change out the dash, or could this be the body control module? Please help with any input. Do not want to get raped at the stealership!
Old Nov 23, 2007 | 10:51 PM
rva33145's Avatar
rva33145
Took the whole dash apart today looking for the culprit. I think I may have narrowed it down to the switch panel on the side of the dash when the dash starts acting up I tap on it an it stops. Ever heard of this?
Old Nov 24, 2007 | 12:25 AM
dgrant3830's Avatar
dgrant3830
Are you referring to the DIC Control on the right side of the cluster?
Old Nov 27, 2007 | 03:41 PM
rva33145's Avatar
rva33145
Yes I am reffereing to the DIC controls. Anyone ever heard of these going bad. They work intermittently when they want to then all of a sudden stop working. Seems like there may be a short on the E/M switch. Can this part be replaced or do you have to replace the whole dash. HELP!!!!!!!
Old Nov 27, 2007 | 04:10 PM
VetteDrmr's Avatar
VetteDrmr
Don't know why the CLB would cause random switching from standard to metric. BC is da man when it comes to things C5 electronic, but my guess would be towards the instrument cluster itself.
HTH, and have a good one,
Mike
Old Nov 27, 2007 | 05:13 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It sounds like you have 2 problems;
1. the DIC controls, the switch is bad and is randomly switching between MPH and KM
2. your CLB has failed and needs to be redone.
Old Nov 27, 2007 | 07:05 PM
dgrant3830's Avatar
dgrant3830
The DIC controller can be replaced by itself, however you have to remove the cluster to get to it as its screwed into the cluster from the rear. I was thinking the CLB may have a problem due to his original posting...maybe he should put it back to normal and try again. As Runamuk mentioned, this might be two problems rather than a single cause.
Old Nov 27, 2007 | 07:47 PM
rva33145's Avatar
rva33145
Anyone ever heard of a DIC control going bad? What is the part number for this part? CLB was working fine. Started acting up and displaying "service column lock" message when I disconnected the positive terminal from the battery and later re-connected it.
Old Nov 28, 2007 | 12:04 AM
rva33145's Avatar
rva33145
To Electrical Problems!! Help!!!!
