Throwing Codes Need Help
Old Nov 19, 2007 | 01:54 PM
98siLVERbULLET!'s Avatar
98siLVERbULLET!
Default Throwing Codes Need Help
I regularly check my computer to make sure everything is running ok. this morning i started my car and it didnt sound quite right. i have never thrown any codes but all of the sudden its going crazy. any help identifying the codes would be greatly appreciated. C1255, B2282, B2262, B2264, U1064, U1016, B2265, B0851, U0196. i just hope its nothing major. Thanks in advance for the help.
Old Nov 19, 2007 | 02:49 PM
ICUALL's Avatar
ICUALL
Best site on the web for DIC Codes and Troubleshooting http://www.gearchatter.com/index.php
C1255 EBTCM Internal Malfunction
B2282 Battery #1 Circuit
B2262 Horizontal Position Sensor Circuit
B2264 Vertical Position Sensor Circuit
B2265 Vertical Position Sensor Circuit
B0851 Battery 1 Out of Range
All the U codes can simply be reset per the manual. You need to look at the C1255 and B codes to see if any end with a (c) as this means it is a current condition. If they end with (h) they are history. I would be most concerned about the Battery 1 codes. How old is the battery ? Have you cleaned and tightened the posts ? Also might take a look at Bill's sticky at the top of the page in the sticky section !
