ReInstalling Lifters ?
Old Nov 21, 2007 | 10:16 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default ReInstalling Lifters ?
hey guys, Im at the part in my head install where Imputting things back together and I was curious if I put the new lifters in the trays or just drop them in their holes? Thanks
Old Nov 21, 2007 | 10:36 AM
MJD's Avatar
MJD
Put them in the trays and then install the trays.
Old Nov 21, 2007 | 11:07 AM
Boob's Avatar
Boob
Point the oiling hole towards the front of the engine. Local machine shop told me when I asked last time.
Old Nov 21, 2007 | 11:11 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, when I replaced mine, I couldn't figure out which direction the oiling hole went. The GM manuals don't say a thing about it either. Now, almost three years later, I simply don't remember which way I did them.
Old Nov 21, 2007 | 11:15 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I guess you can do it either way but I put the lifters back in their bores. Then I put the trays back in place on top of the lifters. I was afraid the lifters would drop out of the trays on my way back to the motor, with my luck.
As far as the oiling hole, I was told either way and that it did not matter since it was not mentioned there was a correct way in any of the manuals.
Old Nov 21, 2007 | 11:40 AM
Corvette-Chris
St. Jude Donor '08
Ok Ill just put them in the trays first and point the oil holes towards the front
Old Nov 21, 2007 | 12:43 PM
vettenuts's Avatar
vettenuts
Did you replace the trays? I did and the lifters were nice and tight for re-installation. I also didn't want to risk re-using my tray with a "10" on it.
Old Nov 21, 2007 | 02:31 PM
Last C5's Avatar
Last C5
What about drilling some 1/2" holes in the lower part of the trays to help oiling?? Saw it somewhere.
Old Nov 21, 2007 | 02:44 PM
MJD's Avatar
MJD
You mean like this:
These are 3/8 inch holes.
Old Nov 21, 2007 | 06:08 PM
Greg_E's Avatar
Greg_E
Originally Posted by vettenuts
Did you replace the trays? I didn't want to risk re-using my tray with a "10" on it.
What are you referring to? Was there a problem with some trays?
Drilling the holes in the trays, allows the oil to drain back into the pan sooner. At high rpms a lot of oil is pumped to the top of the motor. The holes let it drain back, before the lifter cups are filled to overflowing.
Old Nov 21, 2007 | 06:56 PM
vettenuts's Avatar
vettenuts
Some of the trays that had a "10" on the bottom had issues with the lifter angle and the heavier valve springs scrubbed the roller on the lifter and took out the cam as well.
Old Nov 21, 2007 | 09:42 PM
Corvette-Chris
St. Jude Donor '08
No, I didnt replace the trays. I did inspect them though and they looked fine and so did my stock lifters. My new lifters fit nice and tight so I think they will be fine
To ReInstalling Lifters ?
