C1214 CODE fixed
Old Nov 21, 2007 | 09:36 PM
RaleighSS's Avatar
RaleighSS
Default C1214 CODE fixed
Had the ole C1214 Code .... 650$ part at GM ... Sent it to Brandon at ABSFIXER.com for 150 + shipping and all is well.... + it has a warrenty
Old Nov 22, 2007 | 05:07 AM
1BAV's Avatar
1BAV
Cruise-In IX Veteran
Did you send the EBCM in for a rebuild? I've been troubleshooting mine and believe I'm about to do the same. I took the EBCM off this afternoon and will be sending it to Brandon on Friday. I had the C1214 code and nothing else. Is this what you had or did you have additional TCS codes?
Old Nov 22, 2007 | 06:47 AM
RaleighSS's Avatar
RaleighSS
Yes... sent the EBCM in for a rebuild.. I also had on other codes related to the TCS ... Once i reinstaled it i had to clear the existing codes and no problems have been seen. One thing i noticed is if you are going to drive without the unit installed make sure you zip tie the harness away from the belt... it dangles very close....
Old Nov 22, 2007 | 02:36 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Brandon does a great job.
Old Nov 23, 2007 | 01:48 PM
pat03z06's Avatar
pat03z06
Just installed mine that I got back from Brandon. Works like a champ... thanks
I had 1214 and 1277
Old Nov 23, 2007 | 03:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is what needs to be sent to Brandon:
Just the electrical side of the unit,
BC
Old Nov 24, 2007 | 12:54 AM
1BAV's Avatar
1BAV
Thanks for the info. Hope this cures my problem, got the part in the mail today. Not planning on driving until I get the part back, but did go ahead and pull the harness back as you suggested. What about the exposed side of the pump after you remove the EBCM. Does anything need to be put over this to keep dirt, etc. from this part?
Old Nov 24, 2007 | 06:51 AM
RaleighSS's Avatar
RaleighSS
Default nope
I did not cover mine... I only drove it one time... I think it is fine not to cover it as long as you are not driving up and down dirt roads ect... I have seen where people cover it with plastic but again relly think for the few days it will be exposed it will be just fine...
Old Nov 24, 2007 | 07:34 AM
Rob's 73's Avatar
Rob's 73
Bandon fixed my 1214 as well!
Old Nov 24, 2007 | 08:12 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your not going to drive it, it should be fine. Just be sure to inspect the well good before you reassenble it. Dont want to capture any water, moisture or bugs.
1BAV
Can you do me a favor befor you reassemble the EBTCM. I need a picture of the inside cavity of the BPMV. Before you put the module back, is it possible to take a digital picture of the cavity and either post it or send it to me??
Bill Curlee
Old Nov 25, 2007 | 05:30 PM
John D's Avatar
John D
Default Ebctm
I can't belive how easy it was to remove the EBTCM. I followed your instuctions and within 20 mins it was out. I checked and cleand the grounds and will send the unit out tomorrow. I hope this takes care of the problem since I was tring to sell the car but the abs was turning everyone away.
Thanks or the help
Old Nov 25, 2007 | 06:25 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
John
Can you take a picture of your BPMV well where the module came out of. I need it for my post when I help people out.
BC
Old Nov 25, 2007 | 09:31 PM
D C's Avatar
D C
USMC (retired)
Where can I find the instructions to remove this thing?
Old Nov 25, 2007 | 11:15 PM
bdiddo's Avatar
bdiddo
Brandon has instructions on how to remove it on his webpage.
Old Nov 30, 2007 | 03:06 PM
John D's Avatar
John D
Just got back my EBTCM from ABSfixer.com today. Tonight I'll try to install it if I have time, can't wait......
Old Nov 30, 2007 | 07:42 PM
John D's Avatar
John D
FIXED!!!!!!!!!!!!!:
Old Dec 1, 2007 | 12:03 AM
1BAV's Avatar
1BAV
Default It's all done!
Got my EBCM back from absfixer late yesterday and got installed this evening. Started the engine and all the lights went away and checked my dtc's and they were moved to history from current. I'm now a very happy guy! Thanks for everyone's help and to absfixer a job well done!
To C1214 CODE fixed
Old Dec 1, 2007 | 12:45 AM
ptiller's Avatar
ptiller
absfixer did me right!!
Old Dec 1, 2007 | 02:26 PM
WhiteKnight's Avatar
WhiteKnight
Default Screw the dealer, use absfixer.com
I just installed the module I sent to absfixer.com for repair. So far so good and no C1214. I will really be impressed if this stays fixed for another 6 - 12 months. It feels good to screw the dealer for a change. Thanks Brandon!
Old Dec 1, 2007 | 03:22 PM
chaase's Avatar
chaase
St. Jude Donor '12
