Are TPS Sensors Mandatory?
Old Nov 22, 2007 | 01:35 PM
FlyNLow98C5's Avatar
FlyNLow98C5
Default Are TPS Sensors Mandatory?
I have a 98 corvette and was thinking about changing wheels but are the use of TPS Sensors necessary? Will the DIC throw anything if they are not being used. Thanks in advance.
Old Nov 22, 2007 | 02:25 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, you'll get messsages but you can just hit reset. On 2001 and up the sensors can be programmed out but not on the 2000 down.........
Old Nov 22, 2007 | 11:27 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Yes you can use aftermarket wheels but you will get the tire pressure sensor warnings all the time--you can turn it off but it gets annoying--I have aftermarket wheels and i just removed the sensors and installed them on my new wheels--you can do the same--the sensor is a part of the valve stem assy. I don't think you can turn off the sensors permanently but you may be able to with a Tech II--A programmer like HP or EFILIVE won't do it--
Old Nov 23, 2007 | 11:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree ,, why would you not want to have such a valuable asset. Here are pictures of the two style sensors. One is the early sensor, 97-2000 and the newer style 2001 + You CAN NOT interchange them!
2001+
2001+ mounted
early TPS on right compared to new one
BC
Old Nov 24, 2007 | 12:59 AM
chpmnsws6's Avatar
chpmnsws6
After awhile it will not say anything about the tire pressure sensors missing. It will just be blank when you look at the rf/lf rr/lr gauges.
Old Nov 24, 2007 | 12:13 PM
rws.1's Avatar
rws.1
Here are the ones you need.
On special this weekend at
www.GMPartsHouse.com
97-2000 Sensors
10438853 - sensor – 85.89 each
15234846 - nuts – 3.21 each
Total setup of 4 is 390.97 shipped!
To Are TPS Sensors Mandatory?
