Do I need a new balancer (pic inside)
Old Nov 24, 2007 | 11:45 PM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Default Do I need a new balancer (pic inside)
I noticed a little balancer wobble the other day on my 01, and did a search to find this is a common problem. If you look the pic of mine the rubber is the same all the way around except for one spot it dips in.
Does this look like it is separating? Car only has 50k....
thanks,
Jeff
Old Nov 25, 2007 | 12:31 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
buy a new one. Mine done that same thing at 45k.
Old Nov 25, 2007 | 02:29 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
The wobbling crank issue is fairly common. But if left untreated, it can DESTROY your motor.
Pull the pulley, and correct the problem. Or it can get very bad.
Old Nov 25, 2007 | 08:15 AM
CTSV OWNER's Avatar
CTSV OWNER
Fix it before it looks like this
Dave
Old Nov 25, 2007 | 08:41 AM
lp2k's Avatar
lp2k
are there any write ups on how to fix this?
Old Nov 25, 2007 | 10:11 AM
American Hydrocarbon
Guest
Posts: n/a
Fix it now!
Old Nov 25, 2007 | 12:09 PM
jeanlucpicard's Avatar
jeanlucpicard
Go to LS1HowTo.com and download the really good blow-by-blow instructions on pulling the crankshaft pulley. You will need a full day and a six pack at your house garage to do it right.
Old Nov 25, 2007 | 01:27 PM
JCSZ51's Avatar
JCSZ51
Any recommendations on a good underdrive setup, that won't break the bank??
I'm looking at the SLP setup
Old Nov 26, 2007 | 06:58 PM
JCSZ51's Avatar
JCSZ51
TTT
Found that summit poducts also has a underdrive balancer that is pretty much the same as the SLP unit. I'm thinking about picking it up due to the fact it's only $160.
Opinions
Old Nov 26, 2007 | 07:02 PM
vettenuts's Avatar
vettenuts
New Era carries the Powerbond, very nice setup. Its on sale right now too. The Powerbond also has a key milled in it so you can pin your crank with the ATI kit and never worry about it slipping or coming off again.
Old Nov 26, 2007 | 07:40 PM
TLewis4095's Avatar
TLewis4095
We see these alot. Very common problem & if left alone will destroy your engine.
Old Nov 27, 2007 | 07:00 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
TSP had a pretty good deal on their underdrive pulley. It is a Powerbond as well.
Old Nov 27, 2007 | 10:20 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Easy replacement and worth it!
Becasue if it falls off you'll wish you had sprung for a new one!
You might want to do a Underdrive while you are at it! Just a suggestion! = a couple few extra HP's!
Thanks,Matt
Old Nov 27, 2007 | 01:09 PM
Mike94ZLT1's Avatar
Mike94ZLT1
While the balancer is off, you might as well just pull the water pump too, the timing cover is a few more bolts, pop off the cam gear and retainer plate and slide that cam out! Pulling the rack and the balancer is the worst part of a cam swap, and since you will have that done you might as well just go for the gold!
Old Nov 27, 2007 | 05:37 PM
TLewis4095's Avatar
TLewis4095
& add the hi-vol oil pump.
Old Nov 30, 2007 | 06:41 PM
JCSZ51's Avatar
JCSZ51
I ordered a summit racing 25% underdive balancer (only $160) and a factory bold. I haven't tried any of summits new product but the specs are dead on with SLP and for a $100 difference I'll try it!!
I'll post up one I get it in!
Old Dec 12, 2007 | 09:38 PM
JCSZ51's Avatar
JCSZ51
Alright I'm about to start this in the morning. I haven't picked up a cam and am still on the fence about it. Would a 02-04 z06 cam (springs, retainers and everthing) be worth the trouble?
To Do I need a new balancer (pic inside)
Old Dec 12, 2007 | 10:35 PM
500hp's Avatar
500hp
The SLP pulley is all steel and presses onto the crank easier than the tighter fitting aluminum hubbed pulleys.
Old Dec 12, 2007 | 10:46 PM
ISeeRed's Avatar
ISeeRed
If you're gonna change cams and want it to retain ALL of the driveability and want stealth like the ZO6 cams, buy the Lingenfelter GT2-3. It is pure stealth and has more lift, but still allows you to run the Yellow ZO6 springs. I made over 400 rwhp with it along with a set of ported 243's.....You can find it at http://www.lingenfelter.com/Merchant...Category_Code=
Ray
Old Dec 12, 2007 | 11:00 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Ray
That's the route I went as well.
