Catch can not catchin so much...
Old Dec 1, 2007 | 11:34 PM
  #61
Dave68's Avatar
Dave68
The CH can, like other polycarbonate-bowl cans, is temperature-limited to about 120 degrees F. If you are not careful about where you mount it, you can easily experience leakage of unfiltered air into your PCV line - not a good thing.
In addition, that CH can is most likely a particulate filter, not a coalescing filter. Particulate filters can trap liquid oil (as you have seen), but are poor traps for aerosol oil, whether you reverse flow or not.
If you do have this filter mounted up front, in a cool area, consider adding a true coalescing filter (like the Watts in my article) after it. (and don't reverse flow direction through the element)
Old Dec 1, 2007 | 11:49 PM
  #62
ALLEGRO's Avatar
ALLEGRO
It is mounted in the battery area. I have a vented cover for the battery box and I have checked the bowl many times and believe it to be cool enough to work okay. My fall-back is the paper fuel filter that follows the CH. I think that I am in good shape, especially considering I am trapping at least some of the oil.
Old Dec 2, 2007 | 12:24 AM
  #63
Dave68's Avatar
Dave68
From my catch can article:
Maximum temp. in battery compartment during 20 minute ride home on a 75 degree day: 132°F
This exceeds your can's maximum temperature rating, so be careful....
Old Dec 2, 2007 | 01:43 AM
  #64
Dirty Howie's Avatar
Dirty Howie
Originally Posted by ALLEGRO
...with flame-suit on...
I am using a CH catch can complete with the coalescing stone in place. It is installed in "reverse flow" configuration and immediately following it I have a plastic fuel filter inline. All of this is AFTER the OEM PCV system.
I get enough oil in the bowl to be concerned, about the same as mentioned in this thread. I find it amazing that there is this much oil getting by and GM is not more concerned. All my reading suggests that the oil is drawn up during deceleration. My car is not driven very hard and I have the MN6. One suggestion was that it was the derivitive of high rpm and light throttle opening. I don't think I fit that scenario much in my normal driving.
All in all, we all need a system to stop the oil from making the inside of the intake. I intended to move UP to the EE type cans, but mine appears to work well.
...flame suit on......FIRE AWAY.
I used to run this same setup .... but the fuel filter would get soaked at the track and I was concerned that there was no flow any longer.
DH
Old Dec 2, 2007 | 02:12 AM
  #65
NemesisC5's Avatar
NemesisC5
Originally Posted by Andy@AandACorvette
I haven't had a chance to weld it all together and test it yet.
It's made for supercharged cars, anyway.
I'm Supercharged and I Need One Bro, I get dibs on the first one
Old Dec 2, 2007 | 10:12 AM
  #66
Pumba's Avatar
Pumba
A lot less liquid oil gets dragged with the vapor if the oulet is up high.
I agree with Andy on this point. As I mentioned earlier in this post, I believe that you should mount the inlet for the catch can for the hose coming from the valve cover higher than its outlet point on the valve cover to prevent syphoning of the oil out of the valve cover.
In another post, a Forum member told of how he had mounted a catch can from the valve cover outlet to a point low on the passenger-side frame rail. At the end of each track session his catch can was full of oil.
For those who have catch cans in the valve cover to throttle body line, take a look at their inlet, and be sure it is higher than the valve cover's outlet point.
Old Dec 2, 2007 | 11:22 AM
  #67
Dirty Howie
Originally Posted by Pumba
[FONT="Tahoma"][SIZE="3"][COLOR="Blue"]I agree with Andy on this point. As I mentioned earlier in this post, I believe that you should mount the inlet for the catch can for the hose coming from the valve cover higher than its outlet point on the valve cover to prevent syphoning of the oil out of the valve cover.
I'm not sure from the pic and havn't see his AMW mounting height so it may not be higher than the outlet from the filler cap.
I DO KNOW that Andy believes the position of the outlet is most important. In other words the outlet right from the valve cover is geting oil thrown right at it where as it is much harder for the oil to get to the top of the filler cap. He may also have a baffle in the cap???
DH
Old Dec 2, 2007 | 12:05 PM
  #68
2000BSME's Avatar
2000BSME
Originally Posted by J.R.
If you run the car hard i.e. track days or races and still have the oil in the manifold problem after catch can installation you may want to think about restricting oil flow to upper end. This is a problem in most wet sump LS engines.
A lot of racers are using Smith Bros. .040 restriction pushrods (part # 581R) in either stock length (7.400) or if you have milled heads and .040 head gasket a 7.350 length pushrod. These are chrome moly 5/16" x .083 wall.
I like this suggestion.
Old Dec 2, 2007 | 01:34 PM
  #69
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default catch can
why not design a catch can that lays horizontal and the drain has a tube that fits over the dipstick tube, or weld a y end of a tube to the dipstick tube, and let the oil recycle itself?
this isn't really very hard to do.
You will just have to find a nice convenient place to keep the dipstick under the hood when you are not checking the oil
Old Dec 3, 2007 | 01:27 AM
  #70
Lone_sword's Avatar
Lone_sword
Can you run a catch can without the PCV valve?
