Winterizing - Dumb Question
Old Nov 27, 2007 | 02:32 PM
4 KRUSIN's Avatar
4 KRUSIN
Default Winterizing - Dumb Question
Well, I decided to throw in the towel on the weekend and put my car to bed for the winter. I did the usual stuff; change oil, fuel stabilizer, wash, pull battery etc etc. I then wanted to add a little air to my tires and ran in to trouble. For some reason I couldn't get them to take any air. Of course I checked the obvious - my compressor was on. I then tried 3 different nozzles and none worked. I tried 3 of the 4 tires and still nothing.
I recently replaced my tires and have not had to adjust the pressure til now. Since I removed the battery before adjusting the air pressure, is it possible that the sensors are preventing air from being added? If thats not it, is there anything else that it could be?
Old Nov 27, 2007 | 04:10 PM
JagTech's Avatar
JagTech
Your pressure sensors have nothing to do with the air passage into the tire so that would not be your problem. Make sure you are using the correct style air chuck as using the incorrect style will not allow air to enter tire, something to do with pressure monitering they are all that way.
Old Nov 27, 2007 | 04:18 PM
SvetteC6's Avatar
SvetteC6
Same thing happened to me the first time. I read on here that it might be the O-ring from the cap is wedged inside the tire valve instead of the cap.
Old Nov 27, 2007 | 04:32 PM
4 KRUSIN's Avatar
4 KRUSIN
Thanks for the tip. I think that is my problem as well. When I look at the stem without the cap, I see rubber in there. I'll bet its the o-ring. I'll check tonight when I get home from work.
Old Nov 27, 2007 | 04:55 PM
vettenuts's Avatar
vettenuts
Unfortunately it works both ways. I have seen slow leaks for the same reason.
Old Nov 28, 2007 | 12:17 AM
rws.1's Avatar
rws.1
either you used the wrong air chuck, or the cap o ring is the cuplrit or someone wanted to pizz you off and filled your valve stems with crazy glue
Old Nov 28, 2007 | 03:59 AM
lucky131969's Avatar
lucky131969
That's just mean.
Old Nov 28, 2007 | 09:53 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Nov 28, 2007 | 10:17 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Those little O-rings are a pain... I got a set of cheapo generic plastic caps that have the flat rubber washer in them. Took them out of the cheapos and put them in my brass caps. Problem solved
Old Nov 28, 2007 | 12:26 PM
4 KRUSIN's Avatar
4 KRUSIN
Thanks for the help everyone. The forum comes through again.
It was the O-rings and the problem is solved. I had some oversize O-rings that I inserted in the place of the culprits and they seem to stay with the caps.
To Winterizing - Dumb Question
