headlight door operation
Old Nov 28, 2007 | 10:19 AM
missingthedead's Avatar
missingthedead
Default headlight door operation
hey may name is brian i just picked up a 2000 coup and whenever i start the vehicle the headlights pop up.i tried switching the twilight setting to off and the dic is not letting me. anyone pleaseeeeee help. thanks
Old Nov 28, 2007 | 11:36 AM
SR-71's Avatar
SR-71
Are they popping up even in the daylight? On the DIC display does it have twilight listed as being on? It's just a thought but you might try disconnecting the battery for a bit to reset all systems then going in to turn your twilight off. Hope you figure it out...
Old Nov 28, 2007 | 12:10 PM
missingthedead
yes they are going up all the time. i will try the batt disconect thanks
Old Nov 28, 2007 | 03:22 PM
Oldvetter's Avatar
Oldvetter
Do you have anything sitting on your dash, over the light sensor?
You could have a Canadian C5, does your speedometer go up to 300 mph? If so, you have a Canadian car (or at least someone switched the gauges). I don't think Canadian C5's can turn off twilight settings, something to do with daylight driving lights.
Old Nov 28, 2007 | 03:28 PM
missingthedead
its not canadian and i have nothing blocking sensor....i dont think,where is the sensor?? ha ha
Old Nov 28, 2007 | 04:46 PM
missingthedead
i did the battery dissconnect and it did not work still the same.when i get to twilight menu you can see it really fast go from off to on and stays on.
To headlight door operation
