My DynoTune Went Horribly Wrong...
I'm went back in and check the cam alignment, but it's dead on.. Removed the oil pump and oil ring seal is like new, it was never pinched or anything.. I guess only one thing left to do, A Leak Down..
I know I may be asking the obvious questions, but what you are describing sounds like some of these things were overlooked or not done to proper tolerances.
Cam is dead on.. Dot to Dot.. If what I just described is not proper, then I don't need to look any further because then we have found the problem/s.
Don't always trust the dot's....degree it to see for sure. Also, .002-.0025 on the bearings unless it is an all out race motor.
I originally though it was a pinched o-ringed and was on my to do list next. However, now the pressure will not raise past 14-15 psi at any given rpm ( I've gone as far as 3k rpms and it just will not raise. I drove home with some engine noise, but It's hard to describe, it almost felt like it was coming through the center vents.. I never got a warning light and the noise is only coming through under acceleration. Pull the codes and had none, I'd figure, maybe I'll get a knock sensor code, but no..
I came home pulled the front cover off and removed the oil pump. Oil ring was seated properly, looks brand new with no signs of being pinched anywhere. I opened the pump and the relieve valve was stuck closed, shouldn't that be more pressure instead of less. I mean, I had to pry it with a thin screw driver to get it lose. Is the valve supposed to move freely? Can it be a faulty Oil Pump?
Last, I checked the cam alignment and it's dead on dot to dot.. I will be running a leak down test later on tonight.
You only left here mid day yesterday!
it's a shame the build did not go as planned, personally I would pull the motor and completely tear it down. A cam bearing could have walked and personally I think your bearing clearances are too loose anyway. At least it's winter time now and you can take your time and build it right.
100%!!! Best advice here yet. An oil filter will tell you a lot about the engine if something when majority wrong in there. You shouldn't see much copper if any in a new build. But if you have turned a bearing you will most likely see the damage in the filter, no matter how bad the bearing turned.As far as low power, are you sure the pistons decked back to the top of the block? Did you check deck height after assembly? These motors normally run 0 to +.005 (piston slightly out of the hole). If you ended up with the wrong pistons or rods your piston height may be way below the deck causing an extremely low compression ratio. Do a compression check as well as a leak down to eliminate that possibility.
Did the engine run smooth or did it seem to have a miss before the dyno pulls?
