My DynoTune Went Horribly Wrong...
Old Nov 29, 2007 | 02:49 PM
Billdog350's Avatar
Billdog350
Compression: http://en.wikipedia.org/wiki/Compression_ratio
Around 200psi sounds about right....but some of the more senior engine builders on the forum can confirm.
Agreed on dissecting your oil filter to see what's going on in your motor before a complete teardown.
Lastly, what are your cam specs? Those will affect the DCR but should obviously be making way more than 350rwhp.
I recently lost a valve spring/rocker that caused one cylinder to lose compression and the engine ran horribly. Is it possible you have a dead cylinder (spark) causing the low hp values? Since you've checked compression, it is less likely that a spring or rocker failed.
Assuming all mechanicals check out (except the poor oil pressure...maybe lifter?) I'm wondering if you accidentally ended up with a stock LS1 (or near stock) cam ? If you went with something greater than a 224/224 you should have been putting down more than 400rwhp...not 350. I'm sure vendors mess up from time to time...and buying something used from the internet is even more suspect.
Old Nov 29, 2007 | 03:03 PM
BonestockZ06's Avatar
BonestockZ06
My cam is a 233/239 with PRC dual springs and titanium retainers (everything brand new). Valve covers are off and everything looks in tact. Car doesn't miss under normal driving either. Spark plugs are on the money as well with no signs of carbon or fouled.
Oil pump was removed and as I stated before, the valve was stuck on the closed position which I believe it would have raised the pressure instead of dropping it. I'm in the process of leak down and so far I've done 2 cylinders (5% and 4% leak results so far through the crankcase). If the leak down checks, then It has to be a bad cam..
Old Nov 29, 2007 | 03:11 PM
Billdog350's Avatar
Billdog350
The spring that failed on me was a PRC dual gold also. It had about 5k miles on it.
233/239 should be 425-450rwhp with your setup (do you have longtubes?)....not 350. Sounds like a bad (or wrong) cam.
Old Nov 29, 2007 | 03:16 PM
BonestockZ06
I dont have the gold, but they are PRC.. I have kooks LT's with off road x-pipe and Stinger CAI. It should have made more power in stock form, period!
Just sitting here trying to figure out whats the best way to get all the pistons at TDC (compression Stroke) one at a time.. 1 & 6 were easy because of the cam marks, but I still have 6 more to go.
Old Nov 29, 2007 | 05:18 PM
BonestockZ06
Default Leak Down Test Results
Ok, So using the following procedure, there results are as follows"
Cam gear and Crank Gear dot to dot checked 1&6.. Rotate 90* check 8&5.. Rotate 90* check 7&4.. Rotate 90* check 3&2 all locking the crank by placing the car in gear with rear tires on the ground and emergency brake on.. REGULATOR SET AT 100 PSI
#1 produced 5% leak into the crankcase
#2 produced 5% leak into the crankcase
#3 produced 3% leak into the crankcase
#4 produced 5% leak into the crankcase
#5 produced 4% leak into the crankcase
#6 produced 4% leak into the crankcase
#7 produced 4% leak into the crankcase
#8 produced 4% leak into the crankcase
So whats left to look at? THE CAM?
Old Nov 29, 2007 | 08:03 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Do a oil analysis, it will tell a story about your engine, good luck
Old Nov 29, 2007 | 09:07 PM
BonestockZ06
Oil and filter have approximately 60 miles and looks amazingly clean. Looked for signs of metal in the oil pump but nothing was found, I will open up the oil filter next and look for gold colored metal in there. If I don't find anything in there, then the noise could have been valvetrain noise from low oil pressure. Next step is the cam... I need to find a degree wheel and make sure it's not off..
Old Nov 29, 2007 | 09:56 PM
500hp's Avatar
500hp
What lifters are you using? New?
What length of pushrods? How did you decide length?
I wonder if you have a valvetrain issue and not getting full lift from your cam/valves.
I'm not familiar, yet, with the LS1's oiling passages/plugs/circuitry... could there be a plug missing, or something to this effect, causing improper oil flow or excessive bleed-off?
Old Nov 29, 2007 | 10:10 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Is your oil pump on with a spacer to clear a timing chain? If it is, you need to bolt up the pickup first, then the pump.You also MUST use a new O-ring,even if your original one looked fine. This stupid $5 part caused me a lot of headaches. If you do the opposite, the O-ring won't seat, sucks air, and drops the oil pressure.
BonestockZ06
Lifters are stock. Pushrods are 7.4 included in the cam and springs kit which is supposed to be the correct length for stock heads according to the vendor.
No plugs are missing, I made sure of that during assembly. Everything that came off went back on. I did state that the oil pump valve was stuck on the closed position and had to be pried out, but no one has commented on it weather it can be part of the oil pressure issues or not.
Old Nov 29, 2007 | 10:15 PM
BonestockZ06
No spacer was used. There are no clearance issues. The oring is brand new blue gm. It was installed with the engine out of the car and upside down on an engine stand. However, when Installed, I tighten the oil pump to the block first, then I placed the o-ring on the tube, lubed it and inserted it on the oil pump and then tighten the single 10mm bolt. Then placed the other end of the tube over the main stud and tighten.
I removed the oil pump and o-ring looks new, no signs of ever being pinched.. I ordered a new pump and o-ring.
Old Nov 30, 2007 | 12:09 AM
lucky131969's Avatar
lucky131969
Double roller timing set with no oil pump spacers?
Old Nov 30, 2007 | 12:17 AM
  #33
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Absolutely a stuck relief valve will cause low / no oil pressure. In fact that's really what happens when folks claim "my oil pump died".
So I assume you haven't run it since cleaning up the oil pump? My guess is you'll find your lost oil pressure..
As to the low dyno numbers.. ??
Old Nov 30, 2007 | 12:27 AM
  #34
lucky131969
Doesn't quite explain the engine knock
Old Nov 30, 2007 | 09:40 AM
  #35
BonestockZ06
I don't have a double roller timing chain.. I have an LS2... The engine noise is unknown. Like I stated before, just so hard to tell, but I'm hoping it was valvetrain noise rather than a knock.
Old Nov 30, 2007 | 09:47 AM
  #36
BonestockZ06
I ordered a new LingPerf oil pump... I hope that is it..
Old Nov 30, 2007 | 11:39 AM
  #37
lucky131969
I hope so too sir. Good luck !
To My DynoTune Went Horribly Wrong...
Old Nov 30, 2007 | 04:18 PM
  #38
tjZ06's Avatar
tjZ06
It does if the low oil pressure was keeping the lifters from pumping up.
A friend and I went through similar headaches with a fresh forged LS6 build for his '63 Pickup (it's gone 12.3 so far on the motor... and we've since picked up another 20rwhp w/ tuning). In his case it turned out to be the "barbell" plug that goes into one of the oil galleries in the back of the block, under the rear cover. Though, you never would have seen 50psi IMHO if the barbell was out. You should give your builder a call though and ask if they remember removing it and/or installing it. Most builders will take it out if the block got any machine work.
Good luck.
-TJ
Old Nov 30, 2007 | 04:36 PM
  #39
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by ArKay99
New rods, pistons, rings, and bearings is more than a cylinder hone. As Doug suggested do a leakdown. I would also do a compression test. 15psi oil pressure could mean a pinched pickup to oil pump o-ring, or excessive main bearing clearance. Did you verify your clearances when installing the new bearings? What about rotating assembly balance? Di you check your rings for proper end gap?
I know I may be asking the obvious questions, but what you are describing sounds like some of these things were overlooked or not done to proper tolerances.
Hey can you come work on my car man?
Old Nov 30, 2007 | 04:56 PM
  #40
edcmat-l1's Avatar
edcmat-l1
If the bearing clearance really is .003, that could cause a knock and low oil pressure. Clearance should be .0025 MAX, and should actually be tighter than that.
Did you have the crank miked? I have seen out of round journals be passed right over by a machine shop. On a crank that they polished no less. An OOR journal will cause an engine knock after only a few hundred miles. It wont spin a bearing but it will egg one out.
At this point I would be looking at a complete tear down.
BTW, I would also increase the top ring gap .003-.005. Better too loose than too tight when it comes to top ring end gaps. ESP with hypereutectics.
