Replace battery
Old Nov 29, 2007 | 10:42 PM
Fred Linden's Avatar
Fred Linden
Default Replace battery
When you change out a battery, does it make any difference whether you disconnect the + or - first? What about hooking up new one, + or - first?
Old Nov 29, 2007 | 10:47 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
For simple safety sake, its best to remove the ground lead first and put it on last. This prevents you from accidently grounding the wrench when on the positive terminal and welding it to the frame and/or blowing the battery up in your face.
Old Nov 29, 2007 | 11:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Standard and safest practice is to remove the ground lead first and put it on last. Remember!!,,,The correct torque for the battery terminals (97-03 C5's ) is 11 ft/lbs for proper battery to cable compression connection.
BC
To Replace battery
