1st to 4th eliminator
Old Nov 22, 2001 | 02:03 PM
robiferretti's Avatar
robiferretti
Default 1st to 4th eliminator
Anyone have this by pass...is it hard to install....worth getting for the $20 or should i not even bother?
Old Nov 22, 2001 | 02:13 PM
C5Cemo's Avatar
C5Cemo
Default Re: 1st to 4th eliminator (robiferretti)
It's well worth it imo. Installation is real easy, just have to jack up the rear of the car. Takes 5 minutes max.
Old Nov 22, 2001 | 05:48 PM
Patches's Avatar
Patches
My first mod - soon after picking her up. Simple. Just jack the rear up on jackstands, unplug the connector from the driver's side of the tranny, plug the cap into the tranny and plug the main GAGS defeat body into the CAGS connector. Tie the wire up with zip ties and you're done.
Good mod. :D
[Modified by Patches, 4:49 PM 11/22/2001]
Old Nov 22, 2001 | 08:23 PM
vettenuts's Avatar
vettenuts
Default Re: 1st to 4th eliminator (Patches)
I am anxiously awaiting mine from LGMOTORSPORTS. I don't know how you can stand drivng the car without it. I have been almost rear ended because of the stupid thing several times. :mad
Old Nov 22, 2001 | 08:28 PM
JWD01's Avatar
JWD01
Default Re: 1st to 4th eliminator (vettenuts)
Best $20 you'll ever spend :yesnod:
Old Nov 22, 2001 | 08:32 PM
PJW001's Avatar
PJW001
Rob,
Definatly worth having and as previously mentioned install is pretty easy, just jack up the rear, support it for safety then slide under near the rear tranny and install.
If you hit approx 3000rpms on the first shift however you will not have to deal with this issue since it only kicks in in low rpms 1st shift.
Old Nov 22, 2001 | 10:14 PM
JohnGlenn's Avatar
JohnGlenn
I used a 10 cent resistor, like this:
http://www.ls1.com/link_cags.html
Later.
Old Nov 23, 2001 | 12:43 AM
rocknrod's Avatar
rocknrod
Default Re: 1st to 4th eliminator (JohnGlenn)
Paris Texas.......lovin life !
Old Nov 23, 2001 | 01:36 AM
DraftMe's Avatar
DraftMe
Default Re: 1st to 4th eliminator (rocknrod)
Get a Ripper for your next mod. You'll be ready to drive like the :reddevil
Old Nov 23, 2001 | 03:32 AM
Dave68's Avatar
Dave68
I always shift past 2200 rpms once the engine is warm, so the skip-shift rarely intrudes in on my driving style. I've noticed that smaller-engined cars with auto-tannies shift at beyond 2500 all the time, and those engines last over 200,000 miles - makes me not worry about shifting at 2300 or more.
To 1st to 4th eliminator
