Knocking (pinging) under acceleration
Old Dec 3, 2007 | 07:41 PM
sambarnett's Avatar
sambarnett
Default Knocking (pinging) under acceleration
Car is a 2001 with Blackwing intake and Corsa Pace car exhaust. Was dyno tuned in 2004. For the last few months the car now pings under acceleration (still using same 93 octane fuel). I replaced spark plugs and wires to no avail. No check engine light.
Any ideas of what might be wrong?
Old Dec 3, 2007 | 09:29 PM
johnathanrn's Avatar
johnathanrn
what exactly does pinging sound like? Is it a high pitched noise or a low pithced shake/rattle?
Old Dec 3, 2007 | 09:32 PM
sambarnett's Avatar
sambarnett
Low pitched shake and rattle. Like metal bb's in a can.
Old Dec 3, 2007 | 09:38 PM
speedsk899's Avatar
speedsk899
that sounds like detonation! Have you done anything to the car lately?
Old Dec 3, 2007 | 09:50 PM
johnathanrn
well only when im driving about 45 and i accelerate... not gunning it just accelerate about half way i hear i hear a rattling coming from the engine... that the only time i hear that sound. Only mods i have done on teh car are the hypertech chip ( i put the thermostat at 180) and a intake... any ideas?
Old Dec 3, 2007 | 09:54 PM
speedsk899's Avatar
speedsk899
So you have the problem also? Have you tried putting the tune back to stock to see if it is a bad tune?
Old Dec 3, 2007 | 09:55 PM
johnathanrn
No i havent put the stock settings back... should I do that? is it a bad problem? how can i be sure its knocking?
Old Dec 3, 2007 | 10:18 PM
speedsk899's Avatar
speedsk899
It can't hurt to put it back to the stock tune. How long has it been doing it? have you refueled more than once since it started?
Old Dec 3, 2007 | 10:36 PM
sambarnett's Avatar
sambarnett
My tune was done over 3 years ago and never had any problems until about 3 months ago. I have not tried to put the stock tune back in it but I have no way to reload the stock tune. The place that did my tune went out of business. I would at least want to be able to backup the tune before I put it back to stock since I paid $500 for it.
Any chance the knock sensors are going bad?
Old Dec 3, 2007 | 10:43 PM
speedsk899's Avatar
speedsk899
I here ya on the tune! The other guy has the hyperchip tuner that is why I mentioned it. I am not sure if the knock sensors can make noise like that. Someone else is going to have to chime in on that.
Also is it different at different RPM, gear, speed?
Old Dec 3, 2007 | 10:45 PM
sambarnett's Avatar
sambarnett
Mine is not consistent with RPM, gear or speed. It typically does it when its under load around mid RPM range but sometimes its close to redline as well.
Old Dec 3, 2007 | 10:49 PM
500hp's Avatar
500hp
Coolant or oil in the combustion chambers?
What do the spark plugs look like?
Old Dec 3, 2007 | 10:50 PM
sambarnett's Avatar
sambarnett
I had someone else do the plugs but they said they looked fine and didn't mention anything about coolant or oil in combustion chambers. It's not smoking at all if that helps at all.
Old Dec 3, 2007 | 11:56 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There is a new software update for the PCM from the dealers that is supposed to help this issue. I haven't gotten it put in for mine quite yet as they quoted me a high price to do it where as it should only take a few minutes or an hour labor charge.
Old Dec 4, 2007 | 12:13 AM
rustyguns's Avatar
rustyguns
he would lose his tune. your gas station may have changed their wholesaler or just are getting crappy gas now. try this only cost you twenty bucks
buy 93 octane fill tank half way then add one quart of torco then fill it up the rest of the way. drive it easy for 10-15 miles. make sue engine is nice and warm ( oil temp minimum 180 )and gas is mixed up then run it hard and see if it pings.
if it does not ping the gas is bad
G/L
i get this a lot around here...octane is not always what they say it is and it changes week to week at the same stations!
Old Dec 4, 2007 | 09:44 AM
sambarnett's Avatar
sambarnett
Add Torco what? Fuel?
They have 100 octane fuel at the gas pump here. Would it make more sense to try that instead?
Sam
G/L
Old Dec 4, 2007 | 08:44 PM
Point & Shoot's Avatar
Point & Shoot
If it makes you feel any better, I get some occasional pinging under part load as you describe - I get the best results with Hess 93 octane.
Other than that car runs great, plugs look fine, not using oil.
Have tried the Top Tier rated brands including the vaunted Chevron and car ran noticeably worse so I believe that what the sign says isn't always what you're getting...........
To Knocking (pinging) under acceleration
Old Dec 4, 2007 | 09:26 PM
rustyguns's Avatar
rustyguns
Sam
yeah try 100 and see if it still pings
Old Dec 4, 2007 | 10:18 PM
dgrant3830's Avatar
dgrant3830
As nice as it sounds to try, all we get out here is 91 octane.
Old Dec 4, 2007 | 11:39 PM
rustyguns's Avatar
rustyguns
you be surprised how many people sell 100 octane race fuel out there but its 7.00+ dollars a gallon!
