Knocking (pinging) under acceleration
Old Dec 5, 2007 | 01:12 AM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Take it to a qualified tuner and get it tuned. Mine did the same thing until i had a dyno tune.
Old Dec 5, 2007 | 09:45 AM
sambarnett's Avatar
sambarnett
Mine was tuned 3 years ago and never had any problems until a few months ago.
Old Dec 5, 2007 | 12:35 PM
C4B4the04's Avatar
C4B4the04
As a Ford tech, we used to do a top-end clean with a chemical you drew in through a vacuum port to clean carbon off the top of the pistons. It is natural to get some deposits on your engine, even using good gas. Do you have any oil coming through your PCV line or breather? If so, some of that nastyness could also add to your issue.
If you have any access to a boroscope to run down into a cylinder through the sparkplug port you could see the top of the pistons and either confirm or deny you have deposits. I know there are a number of good ways to clean it.....sucking a quart of water into your intake is NOT a good way (saw a Cobra get hydrolocked that way ).
HTH, I would not take my tune off, you know that is not the issue. If you have had no problems for years with it, that is not what changed. Find your weak link (dirty gas, low octane, carbon deposits, etc) and you have your fix!
Cassidy
Old Dec 5, 2007 | 01:32 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I did get mine tuned which did not help at all. I've run Seafoam into it on two occassions that also did not help. I did run the GM Top End Cleaner into it, which did help briefly, but it seems the problem is back. Its going to the dealer on Friday for the software update. A Master Mechanic on corvettemechanic.com says that these updates are needed to compensate for the newer spark plugs plus the other issues that GM has found. Included was for the right tank sending unit that has issues as well.
Old Dec 5, 2007 | 01:37 PM
sambarnett's Avatar
sambarnett
I ran Seafoam through mine as well a few times with little if any improvement.
Old Dec 5, 2007 | 01:44 PM
rustyguns's Avatar
rustyguns
Cassidy
good info! except for mentioning FORD
j/k
Old Dec 5, 2007 | 03:17 PM
Vader 87's Avatar
Vader 87
Make sure that its UNLEADED too unless you like replacing O2 sensors.
Apparently your tune right on the edge for 93 octane. Detonation is bad, but it takes quite a bit to destroy an NA motor. If you were FI I would be really worried. Somebody correct me if Im wrong.
Old Dec 5, 2007 | 03:20 PM
sambarnett's Avatar
sambarnett
It's unleaded 100 I would be putting in.
I know detonation is bad. That's why I'm on CF trying to get help :-)
Old Dec 5, 2007 | 03:26 PM
Vader 87's Avatar
Vader 87
I was mainly commenting on the difference between NA and FI and just stating the fact not informing. I will butt out now, sorry!
Old Dec 5, 2007 | 05:34 PM
Bluefire's Avatar
Bluefire
You're sucking in unmetered air from somewhere. Check for a loose/kinked air coupler and all around the new intake. I could be time
for a tune from a reliable tuner.
Old Dec 5, 2007 | 07:57 PM
PUREFUN's Avatar
PUREFUN
Only thing that stopped it was running Torco. Thought it was bad gas also. Even mixed 100% racing fuel in and that helped. But then eventually it came back and that was when i had it retuned.
Old Dec 5, 2007 | 10:13 PM
sambarnett's Avatar
sambarnett
I ran the tank about dry and then put 100 octane in it. It appears that the knock went away. Guess that rules out my knock sensor theory. Looks like I need a retune I guess eh?
Old Dec 5, 2007 | 10:17 PM
  #33
rustyguns's Avatar
rustyguns
or just run 2 to 4 gallons of 100 with your 93 might as well use that higher timing advance. ZOOOOOOOOOOOM
HOW MUCH $/GALLON WAS THE 100 ?
  #34
rustyguns's Avatar
rustyguns
I BET YOUR 93 OCTANE AIN'T 93 ANYMORE
Old Dec 5, 2007 | 10:20 PM
  #35
sambarnett's Avatar
sambarnett
100 was $6.99/gal. vs. $3.17 for 93.
Old Dec 5, 2007 | 10:21 PM
  #36
sambarnett's Avatar
sambarnett
Unfortunately I think you are right. The cheap gas station bastards...
Old Dec 5, 2007 | 11:25 PM
  #37
SLPRC5's Avatar
SLPRC5
Also get a can of MAF cleaner and clean the MAF. He mentioned installing a intake, check it for leaks. A tune may be needed after the intake install...
Good luck
To Knocking (pinging) under acceleration
Old Dec 5, 2007 | 11:48 PM
  #38
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Old Dec 6, 2007 | 04:03 PM
  #39
rustyguns's Avatar
rustyguns
Good luck
WHAT IS MAF CLEANER? WHERE DO YOU GET IT? WHO MAKES IT?
Old Dec 6, 2007 | 06:32 PM
  #40
Bluefire's Avatar
Bluefire
A can of electronics spray cleaner and a Q-tip worked fine for me. Be VERY careful!
