Antifreeze?
Old Dec 7, 2007 | 01:05 PM
coreyslude's Avatar
coreyslude
Default Antifreeze?
Has anyone changed their antifreeze to the regular green stuff? Seems like it shouldnt hurt anything but i could be wrong.
Old Dec 7, 2007 | 01:13 PM
VetteDrmr's Avatar
VetteDrmr
Considering how easy it is to find Dexcool, and the problems with changing over, I just stay with that.
HTH, and have a good one,
Mike
Old Dec 7, 2007 | 01:17 PM
HD2HVETTE's Avatar
HD2HVETTE
There are no problems with changing over. In my shop I have always recommended another premium brand-I am not a fan of dexcool. I have seen too many problems with other GM vehicles with dexcool. I am sure if you research you will read som of the horror stories. All of my Vettes have been changed.
Old Dec 7, 2007 | 01:38 PM
ICUALL's Avatar
ICUALL
Default Interesting reading on the topic
http://forums.corvetteforum.com/show...42&forum_id=34
Old Dec 7, 2007 | 04:39 PM
hotwheels57's Avatar
hotwheels57
Use "search this forum" in C5 Tech using keywords "Dexcool" and read past discussions. This gets discussed a bunch. It's your car to do with as you please.
I prefer to use DEXCOOL in my cars. If you don't like DEXCOOL for whatever reasons, use one of the other major brands of extended life antifreeze products.
This one discussion popped up in my mind when I read this topic title...
http://forums.corvetteforum.com/show...hlight=dexcool
Old Dec 7, 2007 | 04:43 PM
DeeGee's Avatar
DeeGee
From what I've read dont mix brands
If you want to use a different type flush and replace.
Old Dec 7, 2007 | 04:46 PM
American Hydrocarbon
Guest
Posts: n/a
The General says Dexcool.
Old Dec 7, 2007 | 04:58 PM
LoneStarFRC's Avatar
LoneStarFRC
Eight years of Dex. No problems whatsoever.
Old Dec 7, 2007 | 05:56 PM
lucky131969's Avatar
lucky131969
My last five vehicles have all had dexcool. Never a problem.
Old Dec 7, 2007 | 06:45 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Dexcool here for 5 years no problems.
Old Dec 7, 2007 | 06:54 PM
c4cruiser's Avatar
c4cruiser
While some people think that Dexcool is not a good coolant, GM did install it in all of their vehicles so something has to be OK with it. IMHO, if you follow the vehicle maintenance recommendation for cooling system service, you should not have any problems with Dexcool.
Changing from Dex to the green (ethlyene glycol) coolant can work but you really have to flush out all of the Dexcool. Mix the two coolant types together and you can wind up with a brownish sludge-like material that will clog the cooling tubes in the radiator and the heater core.
I would definitely stay away from the so-called "universal" coolants. Use Dex if that's what came in the car originally and the green stuff if that was the factory fill.
Old Dec 7, 2007 | 07:17 PM
vettenuts's Avatar
vettenuts
Not only is it in my Vette from the factory, but I have converted all my old GM vehicles over from the green "crap" to Dexcool. I have inspected the blocks and radiators with a boroscope and Dexcool keeps them cleaner and cools better (less surface tension). No issues in 10 years but I also maintain it. If you go to IMCool web site and read the technical papers written by GM and Texaco you will find most issues from the 90's stemmed from either low coolant or a defective cap.
As a side story, we used the Sierra coolant as a fuel substitute in some aluminum fuel tanks at work for a number of years. After several years the tanks started leaking. The Sierra didn't protect the aluminum, it corroded and the tanks all leaked.
Old Dec 7, 2007 | 08:41 PM
white90conv's Avatar
white90conv
Changed my 7 year old Dexcool a month ago. The old coolant was crystal clear and I saw no signs of any sludge. I for one see no problems with Dexcool and intend to continue to use it. It is possible that people with
other problems are simpy blaming Dexcool.
Old Dec 8, 2007 | 10:07 AM
JOEY P's Avatar
JOEY P
This is the problem with dexcool. It eats gaskets on some cars. I personaly had to change the intake gasket on my 2002 pontiac grand am gt.........And also if you do a search online you find that there are many class action lawsuits against gm right now for this very problem....There is a list of engines and cars out there that it had effects on. But I did not see the vette on the list....The class action lawsuit is getting ready to be settled so I doubt it is operator error on the owners of the cars that had these problems including myself.... I think the number of cars is up to like 300000...Poor GM with car sales at there all time low I dont think they needed this.
Old Dec 8, 2007 | 04:18 PM
JOEY P's Avatar
JOEY P
Bump
Old Dec 8, 2007 | 05:21 PM
hotwheels57
I'm glad you clarified that with "some cars". Obviously, it doesn't effect every vehicle in which it's used. I've used DEXCOOL since it was first introduced in GM cars. I've used DEXCOOL or PRESTONE orange extended life antifreeze in modified Fox body Ford Mustangs and GM tri five Chevy ('55-56-57) cars with oem sbf or sbc motors and/or GMPP crate motors.
I've never had a gasket eaten. I've seen a few water pump gaskets that appear degraded, but I sure couldn't definitively state it was from DEXCOOL. Since many gaskets are now rubber seals, it might be a thing of the past in more modern engines, anyway.
DEXCOOl got its bad reputation when GM used the supplemental tablets for some reason (LT1/LT4 motors in the '90s). The tablets turned to sludge when the coolant system was exposed to air or poorly maintained. The tablets have been discontinued.
Old Dec 9, 2007 | 01:30 PM
CamaroAJ's Avatar
CamaroAJ
Pro Mechanic
Pro Mechanic
doesn't have anything to do with the coolant used its because of the plastic being heated and cooled all the time and becoming brittle. i have replaced tons of the 3100 and 3400 intake gaskets for that reason. also 5.7L trucks with the plastic intake gaskets.
it does seem from my stand point as i do work on cars everyday at a chevy dealer that GM changed something in Dex-cool as we don't have any problems now that we used to have with the stuff. all the cars my family owns run dex-cool and no problems ever, still looks clean and never had a reason to flush it out.
Old Dec 9, 2007 | 08:10 PM
JOEY P's Avatar
JOEY P
Could you please tell me something....You said in one part of your reply that it has nothing to do with dexcool and it is the gasket....And then you say that gm changed something in dexcool so NOW you don't see anymore of these problems....Which is it.....The gasket is made from plastic on the outer part But the part that makes the seal that is like a thread is not plastic.
To Antifreeze?
