Cam Swap! Easier Way
Old Dec 8, 2007 | 11:53 PM
shihiran's Avatar
shihiran
Default Cam Swap! Easier Way
Hey Vet Buddies I Heard That There Was A Easier Way To Do The Cam Swap Anyone Have The Post.
Old Dec 9, 2007 | 01:17 AM
ILM-Express's Avatar
ILM-Express
MFIC
Old Dec 9, 2007 | 01:20 AM
ZSS2148's Avatar
ZSS2148
Default easier cam swap
through the muffler.
Old Dec 9, 2007 | 05:34 AM
molten vett's Avatar
molten vett
I think he means easy as in doing cam only without removing the heads.
i've heard you can do this by using magnets to hold the lifters up but i;m not sure about the specifics. has anyone else heard of this trick?
Old Dec 9, 2007 | 06:21 AM
Real Enthusiast's Avatar
Real Enthusiast
You just stick a dowel rod (wooden rod) in holes that are in the front of the block to keep the lifters up. Make sure to oil it up so it dosen't splinter or I believe they actually make some metal rods for this purpose.
Old Dec 9, 2007 | 07:35 AM
vettenuts's Avatar
vettenuts
I made rods.
Old Dec 9, 2007 | 10:04 AM
Rob's 73's Avatar
Rob's 73
Vettenuts,
What is the diameter?
Old Dec 9, 2007 | 10:29 AM
shihiran's Avatar
shihiran
More Help
Old Dec 9, 2007 | 11:16 AM
PDQC5's Avatar
PDQC5
I thought the rods/ dowels were only installed as a safety measure? My understanding is when you remove the pushrods and roll the engine around a couple of times that the lifters are held by the plastic alignment guides.
Old Dec 9, 2007 | 11:24 AM
chriswtx's Avatar
chriswtx
5/16" dowl rods. You can buy wooden ones at Walmart in the craft section..
Old Dec 9, 2007 | 11:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep, oil the sticks up, slide them in the holes, rotate the cam shaft a couple of times, then, remove the cam! Its that simple. The sticks press on small taps on the lifer trays and allow friction between the tabs and lifters.
If I remember,,,I think it was 3/16" Dont take that to the bank. The person who I know knows for sure is ENGLANDGREEN! We did it on his car and he still has the sticks,
BC
Old Dec 9, 2007 | 11:31 AM
chriswtx's Avatar
chriswtx
I'm doing a cam swap right now, just bought and used the 5/16" dowels last night. After you have it all apart, rocker arms and push rods removed, and your ready to pull the cam, remove the timing chain, rotate the cam first, then slide the dowels down the oil gallies, they push against the lifters themselves and hold them up...
Old Dec 9, 2007 | 11:32 AM
BitViper's Avatar
BitViper
Sure...write a check to have it done for you!
Old Dec 9, 2007 | 11:39 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,,,5/16. Thanks for the correction.
BC
Old Dec 9, 2007 | 12:16 PM
shihiran's Avatar
shihiran
SO I HAVE A 98 AUTOMATIC WHAT ALL I NEED TO DO.
Old Dec 9, 2007 | 01:28 PM
Thickraybans's Avatar
Thickraybans
Check out the F body cam swap write up here http://www.ls1howto.com/index.php?category=0 They do the heads on swap.
Here is where you install the dowels. If you use wood dowels make them long enough so you can't forget to remove them before you reinstall
the timing gear.
Old Dec 9, 2007 | 01:41 PM
Novakain1970's Avatar
Novakain1970
right or left side?
To Cam Swap! Easier Way
Old Dec 9, 2007 | 01:46 PM
shihiran's Avatar
shihiran
NOW THATS WHAT I AM TALKING ABOUT SWEET PICTUERS TO SHOW.
the timing gear.
Old Dec 9, 2007 | 04:11 PM
vettenuts's Avatar
vettenuts
Yep, 5/16". The lifter trays actually hold the lifters up, the dowels only prevent them from falling. Last cam we did we had one lifter that wouldn't go up enough to extract the cam. Once I figured out where it was I actually used the cam to gently nudge it up a little higher.
Old Dec 9, 2007 | 05:03 PM
PewtVette's Avatar
PewtVette
There was a guy over at ls1tech that broke off one of his wooden dowels inside the block. Personally, I used 5/16" steel rod when I did my Camaro cam. Brakeline can be used as well.
