HELP! Theft deterrent relay location
Old Oct 20, 2023 | 12:27 AM
  #61
mmartinez's Avatar
mmartinez
You might think of taking the car to a reputable repair shop, one that specializes on electrical problems.
Old Oct 20, 2023 | 12:39 AM
  #62
Willows's Avatar
Willows
I don’t know what the heck I’m doing.
Old Oct 20, 2023 | 02:14 PM
  #63
Willows's Avatar
Willows
I’m not ready to give up yet. I’ll figure it out.
Old Oct 20, 2023 | 02:24 PM
  #64
mmartinez's Avatar
mmartinez
I will post this final reply in the hope that you can figure out how the starting circuit works. 12v is supplied to the Ignition switch and power is supplied to the various systems that are needed to start the car. When the key is inserted and turned to the run position contacts on the very front of the Ignition switch press against the keys resistor pellet, there are two black wires with a connector that are connected to those contacts. The two wires are wired to a connector at the BCM, the BCM recognizes the keys resistor value as the correct one and provides a ground to one side of the TDR relay coil. The 12v from the Ignition switch start contacts makes its way to either the Park/Neutral switch if auto, or to the clutch safety switch and then is applied to the other side of the TDR coil. The TDR when energized then closes its contacts and sends power to the starter solenoid.
Old Oct 20, 2023 | 02:26 PM
  #65
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
99.99 % of mechanics are WEAK when it comes to electrical problems …find an auto electric shop !!
Old Oct 20, 2023 | 04:57 PM
  #66
Willows's Avatar
Willows
I have an excellent shop. They work on all years makes and models. Lots of hot rods and vintage cars there. Very capable of fixing this. I just want to fix it myself. Seems like I should
Old Oct 21, 2023 | 07:36 AM
  #67
C5 Diag's Avatar
C5 Diag
Well you said you didn’t know “what the heck you’re doing” concerning your issue so if you have the manual I’d FIRST learn how the starting system works because if you don’t you’ll never diagnose it and you’ll just be spinning your wheels…if you don’t have a BASIC understanding of automotive electrical systems that will make it harder too…if you are able to jump the TDR Relay and the starter cranks we can say that the “load” side of the starting system is fine…you just have to figure out how the “control” side works being that the BCM grounds the control circuit.
Old Oct 21, 2023 | 03:59 PM
  #68
Willows's Avatar
Willows
I appreciate everyone trying to help me out. mmartinez made it as simple as it gets.
i have zero experience with electrical systems so trying to figure it out may take a while. Was expecting to change the oil and do a starter or water pump myself but this was a bit much. I’ll probably just take it to the shop and get it done right before I break something else.
thanks for the input!!
Old Dec 16, 2024 | 08:53 PM
  #69
Smiles9721's Avatar
Smiles9721
Originally Posted by mmartinez
You can clip on to the yellow wire and a ground to check for 12v when the key is turned to the start position. This test will tell you that 12v is leaving the Ignition switch going thru the Park/Neutral or clutch safety switch if it's a 6 speed manual The second measurement is clipping the meter lead to the yellow black stripped and the supply side of a fuse in the fuse box, you should see 12v when the key in the on position. Verify which test does not show 12v and we can proceed from there.
I know this thread is a little over a year old, but i was really hoping to see what these different tests mean. I tested the yellow wire when the key is at the on position and had no voltage. I also checked the yellow/black wire at the same key position and had no voltage. Fuse 14 has 12v when the key is at the start position. Just wondering if you think this means an ignition issue or not? When I jump the purple and red wires it starts right up!
Old Dec 16, 2024 | 09:56 PM
  #70
C5 Diag's Avatar
C5 Diag
If you are not seeing 12 volts at the TDR relay either the clutch pedal or park/neutral switch is bad…just follow the purple wire out of the IP Fusebox…if the yellow wire at the TDR is getting 12 volts the coil side of the TDR relay will energize once the BCM grounds the “Relay Control” circuit…once that happens the “load” side of the TDR relay will close allowing power to energize the starter solenoid.
Old Dec 16, 2024 | 10:15 PM
  #71
Smiles9721's Avatar
Smiles9721
Thank you. The purple wire at the starter is not getting anything over 1v. The TDR wires are as follows: Red wire has 12v, yellow and yellow/black wires have no volts no matter the position of the key, purple wire has 0 volts. I believe this means the ignition is going bad.
Old Dec 16, 2024 | 10:33 PM
  #72
C5 Diag's Avatar
C5 Diag
If you think the ignition switch is bad place one lead of your voltmeter on either test point on fuse 50 (Ignition 2) and the other lead on fuse 14 (crank) at the IP Fusebox…have someone try to start the engine…whatever your voltmeter reads is the voltage drop across the ignition switch…if you are only seeing 1 volt at the starter purple wire you should expect to see 11 volts on the voltmeter…that voltmeter reading is the voltage drop across the switch…if you see a minus sign on your voltmeter don’t worry about that…just look at the number…if seeing a minus just means you have to switch the leads around…you may also have high resistance on either the clutch or park/neutral switch.
Old Dec 17, 2024 | 05:54 AM
  #73
oelarse's Avatar
oelarse
Schematics showing Rob's advice
Old Dec 17, 2024 | 04:32 PM
  #74
Smiles9721's Avatar
Smiles9721
The first test mentioned works just fine and I have 12v. The second test I am not seeing any voltage when connecting the meter to the yellow black stripped wire and I tried multiple fuses in the fuse box. What does the second test failing mean?
Old Dec 17, 2024 | 04:34 PM
  #75
Smiles9721's Avatar
Smiles9721
I tried this test and was not getting anything on the meter. This along with other tests mentioned above confirms the ignition is good and the park/neutral safety switch is good (I have an A4 C5). Does this mean it’s a relay issue?
Old Dec 17, 2024 | 06:49 PM
  #76
mmartinez's Avatar
mmartinez
The second test failing means that the BCM is not supplying a negative or ground on the yellow black stripped wire and thus the TDR will not energize and send 12v on the violet wire. Is the Security light off when the key is turned to the On position. The BCM supplies a ground to the TDR if the BCM receives the correct signal level from the Ignition switch contacts that press against the keys resistor pellet.
Old Dec 17, 2024 | 07:43 PM
  #77
grinder11's Avatar
grinder11
You just gotta LOVE where GM put that IP fuse box. Have to be a damned contortionist to access it.
To HELP! Theft deterrent relay location
Old Dec 17, 2024 | 09:31 PM
  #78
Smiles9721's Avatar
Smiles9721
I’ll have to double check tomorrow before work and get back with you when I see if the security light goes off or not. Thanks!
Old Dec 18, 2024 | 03:28 PM
  #79
Smiles9721's Avatar
Smiles9721
That makes sense to the issue that I’m having. The violet/purple wire is not receiving little if any voltage at the starter. I tested it and with the key in and at the ON position the Security light does go away.
Old Dec 18, 2024 | 04:34 PM
  #80
mmartinez's Avatar
mmartinez
There is one thing you can try and that is disconnecting and reconnecting the negative battery cable after a few minutes. If the car cranks over it means the BCM is causing the no crank. Do you hear the TDR click on when you turn the key to the start position of the Ignition switch?
