HELP! Theft deterrent relay location
Old Sep 2, 2023 | 07:47 PM
Willows's Avatar
Willows
I found two relays there. The second one I found had the purple wire. Not sure what the other one is attached to.
Old Sep 2, 2023 | 09:59 PM
jim993's Avatar
jim993
I think this is the TDR- took me a while to find this in my pictures.
Old Sep 3, 2023 | 12:01 AM
jim993's Avatar
jim993
Check post no 8 with the video. Good insight into no start.
https://www.corvetteforum.com/forums...post1606498997
Old Sep 5, 2023 | 02:10 PM
Willows's Avatar
Willows
These are two relays I found there. One has the purple wire. Both are same 4 pin relay, and going to change both. Only code is 80 no radio communication.
Old Sep 5, 2023 | 02:41 PM
mmartinez's Avatar
mmartinez
I belive the other relay is the column lock relay, did you try inserting a wire jumper between red and violet wires and verify that the engine will crank over?
Old Sep 5, 2023 | 02:57 PM
Willows's Avatar
Willows
I tried testing it with a multimeter when the ignition cranked. The probe wouldn’t go in far enough to make contact. That’s when I thought changing it would work.
Old Sep 5, 2023 | 04:47 PM
mmartinez's Avatar
mmartinez
I don't know what you tested with a multimeter when it cranked over. The wire jumper between the red and violet wires will determine if the TDR is at fault, the car cranks over or the car still doesn't crank over, problem with the starter solenoid or starter.
Old Sep 5, 2023 | 05:16 PM
Willows's Avatar
Willows
I’ll probably jump the starter next. Easier than fooling with the relays. At least I could rule it out if it works.
Old Sep 5, 2023 | 05:38 PM
mmartinez's Avatar
mmartinez
Ok, well hopefully it's the TDR, have you replaced it?
Old Sep 5, 2023 | 07:37 PM
Willows's Avatar
Willows
not yet. Still need to get the part.
wow just found it on Amazon. These are really expensive. Was figuring $20-30.
https://www.amazon.com/GM-Relay-12177235-Pack-2/dp/B076T57FHG/ref=mp_s_a_1_5?crid=10K7HHIX7MS62&keywor ds=omron+12177235+D00&qid=1693963355&spr efix=omron+12177235+d00%2Caps%2C114&sr=8-5&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
Old Sep 8, 2023 | 06:48 PM
Willows's Avatar
Willows
I jumped the purple and red wires on the tdr harness, with the relay out, so it could still be that. The starter is working like it should. The battery and connections are ok. I took out the ignition and will clean it tomorrow. Not sure what to try after that.
Old Sep 9, 2023 | 09:29 AM
mmartinez's Avatar
mmartinez
If the TDR clicks on each and everytime you turn the key to the start position there is nothing wrong upstream of the TDR. I will ask again if you have replaced the TDR, you state that jumpering the red and purple spun the starter, so it has to be the contacts inside the TDR.
Old Sep 9, 2023 | 12:37 PM
  #33
Willows's Avatar
Willows
I’m going to get a new relay. There’s used ones on eBay for cheap that claim to have been tested. Might as well clean the ignition too since the car is down anyway. I can get that side put back together and go from there.
Old Sep 9, 2023 | 01:15 PM
  #34
mmartinez's Avatar
mmartinez
Alright then, best of luck, keep us updated.
Old Sep 16, 2023 | 04:25 PM
  #35
Willows's Avatar
Willows
Got a used tdr on eBay. Seller said it was checked. Put it in and got the same result. Clicks when I turn the key but nothing else. My guess is the part must be bad. I’ll have to get a new one and see what happens. I assume there’s non oem parts that will work. If the plugs and schematic is the same it must work the same.
Old Sep 16, 2023 | 08:37 PM
  #36
mmartinez's Avatar
mmartinez
Use a clip on test lead to attach to the purple wire at the starter solenoid and attach the other lead to ground this is the sure fire way to determine that 12v is being sent from the TDR.
Old Sep 17, 2023 | 10:32 AM
  #37
Willows's Avatar
Willows
will do, thanks.
To HELP! Theft deterrent relay location
Old Sep 29, 2023 | 07:11 PM
  #38
Willows's Avatar
Willows
I bought a brand new tdr and still the same issue. Clicks when I try to start the car but no starter. Tried jumping the purple and red wires and the car started. Cleaned the ignition and charged the battery, not sure what to try next.
Old Sep 29, 2023 | 09:03 PM
  #39
mmartinez's Avatar
mmartinez
The only thing it could be is the TDR socket itself, if the TDR clicks each and every time you turn the key to start, and it starts by jumping the red and violet wires it has to be either the red or violet wire contacts inside the socket.
Old Sep 30, 2023 | 08:48 AM
  #40
Willows's Avatar
Willows
It may have come loose when I was removing the old one.
how tricky is bypassing it? I read grounding one of the wires will do that.
