Need Tech Support for my new C5
Secondly, when I'm running the temp is around 195, but when I stop in traffic, it goes up to 230. I this normal??
Also, the LED display for the A/C controller stopped working, now I don't know what function the heat/cooling is on. Is there a fix for this?
Lasty, how do you adjust the headlights, mine are pointing up to jupiter.
I absolutely love this car, I just made a 3000 mile road trip from CA to LA!! I will post all the pics and describe the awsome adventure in an upcoming thread. Thanks, Jeff
Second, the temperature going up to 225-230 sitting in traffic is normal. Mine runs at about 190 moving, but climbs up in traffic the same.
Third, the headlight adjustment is on the headlight assembly, but you have to remove the black surround to get them. Be warned they are known to break with the slightest bit of pressure. Use some WD40 or something like it and spray the units and give them time to free up before working with them. It can be a pain, but with patience you can get them adjusted.
The A/C unit is also a common problem, there is a lot of information on this in the Tech section, you will have to remove it form the car and do some solder work on the control board. Sorry if that is not much help.
I hope this information helps, and if you do some searching in the tech section, you will probably find even more information.
here are links to two previous good DIY posts
http://forums.corvetteforum.com/show...headlight+gear
http://forums.corvetteforum.com/show....php?t=1767764
re the Dim display
here are two good threads for you to educate yourself whether to DIY, or remove and have digitalguy_1@charter.net fix it for you for $50.
http://forums.corvetteforum.com/show...FC+dim+display
The only issue I have left is the coolant temp. I did a test today and noticed that both cooling fans turn off when I turn off the A/C. Turn on the A/C and both fans come back on and the temp falls to around 195. Is there a relay somewhere that I need to check and replace??
Thanks, Jeff
