Getting ready to do a clutch swap (along w/ some other goodies) in my 02 Z. It has just passed the 20K mark. What else (clutch related) should I change out while doing this? I assume pilot bearing, anything else?
With only 20K on the clock I'm thinking master/slave should be ok but thought I would get some opinions.
See I owned a bunch of mustangs before buying the vette(best decision ever) so all of these things are new to me. What the hell are the torque tube bushings?
Clutch
Master cylinder
Slave cylinder
Remove bleeder
Pilot bearing
New nuts for rear cradle (many don't replace, service manual calls for them)
Exhaust gaskets
If you are stock, likely new nuts/possibly studs for exhaust manifolds
Tranny jack, two is better
I used a laser level to aid re-installation.
Defintiely do the pilot bearing, slave cylinder and throw out bearing. Add a remote bleeder too. You can go either way on the master. It is easy to replace later. Don't worry about the torque tube bushings unless it is raced a lot. I also just reuse the cradle nuts and exhaust manifold bolts.
St. Jude Donor '10
take my advice and dont buy a textralia clutch they make the worst sound out of first and the only way for it not to make it is if u just drop the clutch and take off..
St. Jude Donor '10
Originally Posted by vettenuts
I have the Textralia X-grip, drives just like stock with no sounds or noise.
i belive i have the z-grip but i was not told there even was a z or x grip...i ordered it from westcoastcorvettes and i got my clutch that skreeches like i bird or something...
