Spark plug help
Old Dec 11, 2007 | 09:25 PM
mickey_7106's Avatar
mickey_7106
Default Spark plug help
im gonna install my LG headers 2morrow and i want to replace my plugs also. what do you guys recomend? my car is pretty much stock exept for CAI and Exhaust, the car has aprox. 70K miles
TIA
Old Dec 11, 2007 | 09:52 PM
mickey_7106
it seems like ngk is the way to go...
Old Dec 11, 2007 | 10:00 PM
Gideon's_Test's Avatar
Gideon's_Test
NGK's
Old Dec 12, 2007 | 08:39 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Ngk Tr55
Old Dec 12, 2007 | 10:25 AM
jovette's Avatar
jovette
NGK TR55IX (Iridium) is what I installed on my '00 Coupe.
Old Dec 12, 2007 | 10:49 AM
lucky131969's Avatar
lucky131969
Originally Posted by Doug@MorosoPerformance
Ngk Tr55
What is the advantage with NGK compared to Delco Iridium?
Old Dec 12, 2007 | 12:12 PM
vettenuts's Avatar
vettenuts
TR55 is a copper core plug and conducts better. You in theory have to change more often but a lot of guys are getting a lot of miles from the TR55 plugs, to the point of feeling guilty pulling them out because they look so good.
Old Dec 12, 2007 | 01:09 PM
lucky131969
So what is the result of running NGK's? More horsepower? I have not seen a dyno chart for a spark plug change yet.
Old Jan 12, 2008 | 12:28 PM
rayb_satx's Avatar
rayb_satx
hmm... why would a copper core be better than iridium??
Old Jan 12, 2008 | 03:17 PM
thetaxman's Avatar
thetaxman
in a stock motor plugs do not affect HP unless they are worn or they are for the wrong application
Old Jan 12, 2008 | 06:10 PM
robert miller's Avatar
robert miller
tr55 will work best for you at your stage of the car..
Old Jan 12, 2008 | 06:30 PM
BlackZ06's Avatar
BlackZ06
I don't get this "love affair" with the NGK plugs .....
The GM recommended plug for your engine is the AC Delco 41-985 (GM part # 12571164 ) ....
The plug comes CORRECTLY pre-gapped at 0.040 for your engine .....
see .... http://www.acdelcotechconnect.com/pd..._03D-J-171.pdf
for info on the swap to these plugs from the "original" platinum plugs ....
Old Jan 12, 2008 | 06:51 PM
lucky131969
Plenty of 10 second cars running GM Iridium plugs.
Old Jan 12, 2008 | 07:29 PM
rayb_satx's Avatar
rayb_satx
hmmm i found the ngk's cheaper.... $50 shipped..
i woiuld take the ACdelco's if anyone knows where i can find them cheaper....
Old Jan 12, 2008 | 07:40 PM
BlackZ06's Avatar
BlackZ06
http://www.gmpartsdirect.com/ lists them for $5.20 each (use the GM part number to locate them ... which is $41.60 plus shipping) ....
and Napa Auto Parts stores carry them on the shelf. Call your local store (the on-line at http://www.napaonline.com/ doesn't list a price for them) and use the AC Delco part number to get a price.
Old Jan 13, 2008 | 11:56 AM
waterzap's Avatar
waterzap
I think people make too much about plugs. Use NGK and be happy. I challenge anyone to feel ANY difference just on using a different plug..copper, iridium etc. Maybe if you can measure combustion in the chamber you can see a difference. In real life, no way.
Old Jan 13, 2008 | 04:34 PM
speedsk899's Avatar
speedsk899
Old Jan 15, 2008 | 02:49 PM
Ron222's Avatar
Ron222
TIA
Hey Mickey,
You're gonna love those LG streets I just had them installed on my '04 not more than a month ago along with a low temp thermostat, the ever popular NGK TR55 plugs ($2.49 ea)and a Dyno Tune. Something else you may or may not want to consider are the Locking Header bolts. They only cost around $40.00 and prevent the header bolts from backing out. The shop I use recommended them as they have seen some of the bolts on occassion back out. My feeling was I got this much in it I'm not going to worry about the xtra $40.00. (peace of mind).
Hope this helps.
To Spark plug help
