Batery drain (again)
Old Dec 13, 2007 | 04:39 PM
GS023's Avatar
GS023
Default Batery drain (again)
I know there are a gazillion posts on battery drain and I have looked through them. Am pulling high amps and draining battery. I followed the "hook the amp meter up and pull fuse" procedure and when pulled mini fuse "25" the amps dropped way off. I am working on an 02 with a 98 FSM so I think some things have changed. The fuse panel cover says BSM 1 and IPC. With the fuse pulled the car will not start. Also unhooked BSM 1 completely and amps did not drop. Any suggestions on where to go from here?
Old Dec 14, 2007 | 05:09 AM
GS023's Avatar
GS023
ttt
Old Dec 14, 2007 | 07:15 AM
trussme's Avatar
trussme
You might send Bill Curlee a PM on this matter...he has a wealth of knowledge in electrical issues
Old Dec 14, 2007 | 10:21 AM
GS023's Avatar
GS023
Done, Thanks
Old Dec 15, 2007 | 09:00 AM
GS023's Avatar
GS023
Still looking for suggestions before I take the dash apart.
Old Dec 21, 2007 | 07:28 AM
GS023's Avatar
GS023
Default drain
1 mo time
Old Dec 21, 2007 | 01:50 PM
Alex99's Avatar
Alex99
Hi,
I've experienced exactly the same problem like you did.
My battery was drained in less than 1 day and by pulling the fuse 25 the draw was reduced from 7.xxA to 1.5A when the system was awake and from 3.xxA to 1.5A when the system was asleep after 20 min.
I'm still trying to find out what else the reason could be but I've not experienced any other problems or disfunctions.
Please help!
Thanks,
Alex
Old Dec 22, 2007 | 05:12 PM
Alex99's Avatar
Alex99
just for the record. I've resolved my battery drain problem by turning the interior illumination **** out of the steady light mode. The **** is located under the HUD buttons.
Old Dec 22, 2007 | 05:43 PM
GS023's Avatar
GS023
I only wish mine could be that easy.
Old Dec 22, 2007 | 07:11 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Did the same and did not realize the light was on due to the hatch cover hiding the lights that it turns on.
To Batery drain (again)
