think my motor seized - how does one test this?
Old Dec 20, 2007 | 09:24 AM
brookman's Avatar
brookman
do you have any more details yet? I don't live too far from you and I could help you take a look at it.
This actually directed at Joe0121. I am nowhere near Anthem ;-)
Old Dec 20, 2007 | 09:44 AM
Togo's Avatar
Togo
Originally Posted by Joe0121
Step 1 in the AM is give MTI a call
Of check the oil level and color, go into Diagnostic mode and see if you get any codes.
i have had the car for a couple years, so my guess is that the motor is out of warranty
i checked the oil when i removed the dipstick and tube during the starter install - it's dirty and a tad low, but it has oil in it.
i haven't checked codes yet, as the battery died and i had it on the charger - i'll check those too, but personally i don't think that would tell me anything about a mechanical failure such as this
Originally Posted by csdunaway
Did you check your oil level? If you lost your oil, you likely siezed it. I know there could be other catastrophic failures, but a dipstick check is easy...
Originally Posted by eurospec1
You cant get any kind of a socket or bar on a c5 without removing the steering rack,
Id be looking at the clutch, the space between the clutch and the bellhousing is not very much, if something went wrong in there it can bind up the motor, since you just had it changed 500 miles ago that would be my first guess.
Try pushing the car in gear, have someone rock the car back and forth in gear while you watch the crank pulley. The engine should turn slightly back and forth, if it doesnt start removing parts until it does (ie starter)
is there a dust shield under the clutch area like on most cars? i didn't get a real good look under there as i was too focused on the header and starter!
Originally Posted by LDB C5
Check the oil level & color on the dip stick
Pull all the spark plugs
With the plugs out and the car in nutral; you may be able to turn the engine over using the belt by hand.
Originally Posted by Doug@MorosoPerformance
As mentioned above pull the plugs before you do anything else. You may have a hydraulicked engine due to a injector leaking.
lots of great suggestions guys, thanks i have some work to do today!
i'll pull the plugs and have a look, but if the motor is "hydro locked" what can i do to remedy that?
i just got out of bed so i'm going to get cleaned up so i can go out and get dirty when the sun comes up and takes the chill off!
Old Dec 20, 2007 | 09:53 AM
LDB C5's Avatar
LDB C5
IF the engine is hydro-locked; pulling the plugs and turning it over by hand will force whatever liquid that has found it's way into your cylinders, out through the spark plug holes.
What was it doing before this problem? shifting issues? clutch issues? unusual noises?
Old Dec 20, 2007 | 10:57 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I am wondering what is going on myself, usually a catastrophic engine failure or seizure has some warning signs. Dirty oil and a bit low doesn't seem like the culprit. The weather is really cold and we have had a lot of rain recently. He can also check to see if he is getting fuel or a spark maybe the engine is turning over and just sounds like it isnt.
Old Dec 20, 2007 | 12:00 PM
lucky131969's Avatar
lucky131969
Your replies are as humorous as your avatar. Keep em' coming....
Old Dec 20, 2007 | 12:18 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I got nothing man,
I have no clue whats up with his car, but I know what he's going through my car is a paper weight at the moment. In any case I hope his engine is ok, and he doesn't have to part his ride out. Just weird, bamb one day the engine wont start.
Old Dec 20, 2007 | 12:37 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
And you can use a crescent wrench on the crank bolt to try to turn it over, you'll never get a socket on it without removing the rack.
Old Dec 20, 2007 | 04:12 PM
jedblanks's Avatar
jedblanks
I bet its a bad battery. Even if you fully recharge it, if it fully discharged it may be toast. Especially if its 2 years old or so.
Probably no Cranking Amps left.
Voltage won't tell you anything.
Do you have a load tester? Where you can load the battery and see if the voltage drops?
You showed no signs of engine related failure, so start with the simple things.
Battery
Belts (already mentioned)
Clutch
Crank with no plugs (you can try this with the key after you take the plugs out -- should spin with no plugs even with low battery)
Old Dec 20, 2007 | 04:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i vote on the dead batt.
Old Dec 20, 2007 | 06:45 PM
Marcs c5's Avatar
Marcs c5
first thing I would check on a C5. Very common.
Old Dec 20, 2007 | 06:49 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check battery and cables to verify that they are tight and use another vehicle to jump your car.
If your engine turns over, it's more than likely a bad battery.
I was able to get a 24MM swivel socket on from underneath my car and turn my crank when I was doing my tranny conversion, so it can be done.
Had to turn the crank to position the lock bolt on the flex plate braket holding the front drive (TT) shaft.
Old Dec 20, 2007 | 08:35 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Always check the simple things first
That would suck to replace the engine only to have the same problem
Old Dec 21, 2007 | 12:29 AM
  #33
rustyguns's Avatar
rustyguns
Originally Posted by PFMC3
Pull the plugs and rotate the motor.
See if it turns
Old Dec 21, 2007 | 12:32 AM
  #34
rustyguns's Avatar
rustyguns
yeah i had one of those hardened steel clutch guide pins fall off in the bellhousing, could definitely cause this!
Old Dec 21, 2007 | 01:01 AM
  #35
Autobot's Avatar
Autobot
I am going to ask a stupid question but are you sure that your car is in Park if it is an auto? My friend just called me up and said that his car wouldn't start and called me to help him out. First thing we checked was the battery seemed okay, we were going to check the starter but couldn't take a very good look in a parking lot of a store at night and were about to leave. I then asked him the stupid question and he pulled it out of park back in and presto engine was back. Not sure if it works on vettes but it might fire up in Neutral as well.
As for hydro locking, not sure if it is the same on GM or not but for Fords if the fuel rail pressure sensor goes bad and the ECU thinks that the pressure is 0 it will hold the injectors open longer to let you limp home while in reality you have full pressure. It doesn't take long to fill up the cylinders, ask me how I know.
Hope you get your issues solved.
Old Dec 21, 2007 | 07:33 AM
  #36
WKMCD's Avatar
WKMCD
Old Dec 21, 2007 | 09:09 AM
  #37
AMRAAM's Avatar
AMRAAM
That's a good thought and definitely worth trying, but he said he could hear the starter engage. I don't think he would hear anything if it wasn't in park.
To think my motor seized - how does one test this?
Old Dec 21, 2007 | 09:26 AM
  #38
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Check to see if raw gas streams out. If it's not siezed up and the starter is OK the starter should turn the mill over with no problem.
If its a mechanical sieze (valve) oil seize the starter won't do a thing.
Was it running OK when you shut it down?
How long was it shut down?
We had a 327 in a 56 Chevy seize at the drag strip once. Low oil and my buddy ignored the pressure. We pulled the plugs, squirted in some oil through the plug holes, filled it with oil, put the plugs back in. Starter would not turn it, but we pushed it with a wrecker, bump started it in 2nd gear and it fired.
Got it on the trailer got it home and tore it down. Belive it or not ther was no damage. We rebuilt it anyway, but a mechanic friend of our said it would have been ok to use the old rings etc.
Good Luck
Old Dec 21, 2007 | 10:24 AM
  #39
jovette's Avatar
jovette
It has manual trans...........just put it in 4th or 5th gear and give it a little push / rocking motion, and see if the engine will turn, if yes, check battery, if no, you've got something binding........given your recent clutch / flywheel replacement, I'd guess that's where your problem is. You can go ahead and remove spark plugs and alternator belt and try those approaches, but I'd be really surprised if you had hydro-locked motor or bad alternator.
Let us all know what you finally discover to be the problem!!!
Old Dec 21, 2007 | 01:58 PM
  #40
corvettebob1's Avatar
corvettebob1
I bought a car once that had "a seized engine" when I finally got time to look at it.
I put up on a hoist and found a hole in the flywheel inspection cover so I removed it and turned the engine over in reverse and a rock fell out.
It turns out it was wedged between the flywheel and the starter, I replaced the starter and flywheel and drove it for 2 years.
Then sold it for waaay more then I paid for it.
