think my motor seized - how does one test this?
Old Dec 19, 2007 | 10:27 PM
Togo's Avatar
Togo
Default think my motor seized - how does one test this?
i had what i thought was a starter problem, it sounded like the starter was grinding on the flywheel (that was my preliminary diagnosis) so i pulled the starter today and put a new one on, i go to crank it over, and on a full battery charge, i hear a clunk like the starter gear is meshing with the flywheel and it is not able to turn the flywheel.
so, how can a "parts changer" like myself go about testing to see if it is actually seized?
and if so, what to do next????
Old Dec 19, 2007 | 10:29 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I'm all ears, oh and BTW This Sunday can I come over and use your lift so I can diagnose an Electrical issue.
Old Dec 19, 2007 | 10:33 PM
PFMC3's Avatar
PFMC3
Pull the plugs and rotate the motor.
See if it turns
Old Dec 19, 2007 | 10:36 PM
Cart99's Avatar
Cart99
This may be a long shot, but I actually witnessed this happen to a friend of mine years ago. His starter would not turn the engine over, and a mechanic diagnosed the problem as a siezed engine. It turned out to be a siezed alternator! Not saying this is your problem, but it would be worth a try to remove the belts just to make sure it's not something simple.
Old Dec 19, 2007 | 10:48 PM
Togo's Avatar
Togo
See if it turns
how do i turn it? if the starter won't turn it over, what do i use, and how/where?
Old Dec 19, 2007 | 10:49 PM
Togo's Avatar
Togo
i'll try that - but not until daylight - i sure hope that's the problem, it'll be a lot less expensive!
Old Dec 19, 2007 | 10:50 PM
Togo's Avatar
Togo
i don't have a lift - at least not yet, and if this motor is actually seized, i won't be getting a lift for a very long time - or at least until i get the car parted out!
Old Dec 19, 2007 | 10:58 PM
lucky131969's Avatar
lucky131969
This was on an engine with a serpentine belt?
Old Dec 19, 2007 | 10:59 PM
lucky131969
That's ballsy dude! This poor guy might have a serious problem with his car, and you want to use his lift? Why don't you go over and help him out?
Old Dec 19, 2007 | 11:14 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I'd love to help the guy out, I have no idea how to un seize a motor. I was half joking anyways, seeing as my C5 won't run for more than 15 minutes before the battery dies.
Actually, I have tomorrow off I could bring some beer.
Old Dec 19, 2007 | 11:18 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
What year is your car? A brand new Ls6 is around 6200 bucks. What event lead up to this? Is your flywheel ok? are the teeth still intact?
Old Dec 19, 2007 | 11:33 PM
Togo's Avatar
Togo
it's a '99 with a 408
the only event i can think of is that my clutch and flywheel were changed about 500 miles ago or so - and for me to determine if that had anything to do with it, i'll have to start disassembling the car!
i didn't check the teeth, as my first thought was engine seizure, but my 2nd thought was simply that it was the starter.
when it stopped working, i was sitting in the driveway getting ready to go to work, cranked it a couple times, then it just started grinding the starter - so like i said, my first thought was that the starter was grinding on the teeth of the flywheel - i thought more realistically, and assumed it was just the starter so i changed it, and that's where i'm stuck now.
for kicks, i'm going to remove the belt and hope it's the alternator - as i have had some problems with that in the past!
any other suggestions for me to try tomorrow?
Old Dec 19, 2007 | 11:38 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
How old is the engine and who built it? The builder should help you out since it's his engine that is KIA (if indeed is is toast) but it showed no issues before. Did you check the starter fuse? I think you need to get the front of the car up and look at the starter while someone tries to start the car. Where abouts in Phoenix are you located?
Old Dec 19, 2007 | 11:59 PM
Togo's Avatar
Togo
MTI built the motor, but i bought the car from the original purchaser
the starter seems to work, i hear it engage, it just doesn't turn the motor over.
and i'm in ANTHEM
Old Dec 20, 2007 | 12:06 AM
hermit's Avatar
hermit
Pull the plugs, get a socket on a long breaker bar that fits over the bolt on the balancer and turn the motor by hand. I wouldn't try the starter any more untill you determine that there is not something like a cylinder full of water so you don't risk bending a rod.
Old Dec 20, 2007 | 12:08 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
and i'm in ANTHEM
Step 1 in the AM is give MTI a call, step 2 is move to a reasonable side of town. My G/F lives in Buckeye and thats where my 99 is sitting in her garage.
Of check the oil level and color, go into Diagnostic mode and see if you get any codes.
I'm going to sleep I'll check back in the AM.
Old Dec 20, 2007 | 06:43 AM
clif's Avatar
clif
St. Jude Donor '09-'10
Did you check your oil level? If you lost your oil, you likely siezed it. I know there could be other catastrophic failures, but a dipstick check is easy...
To think my motor seized - how does one test this?
Old Dec 20, 2007 | 07:19 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
You cant get any kind of a socket or bar on a c5 without removing the steering rack,
Id be looking at the clutch, the space between the clutch and the bellhousing is not very much, if something went wrong in there it can bind up the motor, since you just had it changed 500 miles ago that would be my first guess.
Try pushing the car in gear, have someone rock the car back and forth in gear while you watch the crank pulley. The engine should turn slightly back and forth, if it doesnt start removing parts until it does (ie starter)
Old Dec 20, 2007 | 08:12 AM
LDB C5's Avatar
LDB C5
Check the oil level & color on the dip stick
Pull all the spark plugs
With the plugs out and the car in nutral; you may be able to turn the engine over using the belt by hand.
Old Dec 20, 2007 | 08:13 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
As mentioned above pull the plugs before you do anything else. You may have a hydraulicked engine due to a injector leaking.
