RING REPLACEMENT FOR OIL USERS
1) Isn't the ring fix supposed to cover just the #2 cylinder? All of mine were replaced.
2) Is having all of the rings replaced more beneficial than just the one set?
3) What type of break in procedure should I use? The dealer told me that no official break in is required after this fix; however, he said he would run it conservatively for a while.
I would also like to say that Connell Chevrolet in Costa Mesa did an excellent job on this service from a customer relations standpoint. I was given a Suburban as a rental, and generally treated better than other dealerships where I have had service done. Anyway, it remains to be seen if this work is actually going to resolve my oil consumption. I have already noticed less build up on my exhaust tips.
Thanks for your input!
The fix calls for the #2 compression ring to be replaced on ALL pistons.......not the full set of rings on just the #2 Cylinder. :D
Also I think the oil ring expander is replaced, but the rails are retained.
Hope the fix works out for you; don't know why it shouldn't if you had a good tech.
Good luck.
Mark
Anyone know when the cut-ins took place?
[Modified by Scruffy, 12:55 PM 11/26/2001]
Piston and Connecting Rod Assemblies
The pistons are cast aluminum. The pistons use two compression rings and one oil control ring assembly. The piston is a low friction, lightweight design with a flat top and barrel shaped skirt. The piston pins are chromium steel. They have a floating fit in the piston and are retained by a press fit in the connecting rod. The connecting rods are powdered metal. The connecting rods are fractured at the connecting rod journal and then machined for the proper clearance. Interim 2001 and all 2002 applications use a second design piston with graphite coated skirt.
I'd hate to have the lame butt tech's we have here in Charlotte tear my engine apart when it really didn't need it.
Anybody know the build range on the recall/repair?
Did they send a recall letter ever or is it simply from having an oil consumption study done by the service center?
Thanx for any info!
Higher Than Expected Oil Consumption (Replace Rings)
1999-2001 Chevrolet Camaro, Corvette
1999-2001 Pontiac Firebird
with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
Condition
Some owners may comment on higher than expected oil consumption. When checked, the oil consumption could be in the range of 400-600 miles per quart (700-1000 km/L).
Cause
The cause for this condition may be an interaction between the piston rings and the cylinder bore in vehicles that are operated at higher RPMs -- typically manual transmission vehicles driven in a manner where the engine is frequently or consistently operating at greater than 3200 RPM.
Correction
A new set of piston rings is currently available through GMSPO. The new rings are part of a complete piston ring kit. Install only the number 2 compression ring and the oil expander ring from the piston ring kit. All other rings in the piston ring kit should be discarded. The original number 1 compression ring and the oil ring rails should be re-used in their original positions on the piston. All pistons should be used in the same cylinder bore.
Important
Do not dress or hone the cylinder bore. Nothing should be done to change the bore finish for this condition. Changing the bore finish may aggravate the condition.
Refer to the Unit Repair Manual for appropriate ring removal and replacement procedure.
The number 1 compression ring and the upper and lower oil expander rails are re-used because they are already broken in for the bore that they are in. The new number 2 compression ring is made with a very sharp edge that will break in quickly.
Changing only the piston rings noted, with no change in driving style, should change oil consumption to an acceptable level. Changes in driving style that reduce the amount of time spent at higher RPMs will also positively effect oil consumption.
In addition to the standard size piston ring kit listed below, a 0.25 mm oversized piston ring kit is available. The oversized piston ring kit should only be used in those rare instances where the cylinder bore size has been machined larger to accommodate the 0.25 mm oversized piston rings.
I took the car to St. Louis over the weekend and no oil consumption. That is a positive sign. Time will tell if it remains that way, but I have my hopes up.
Best of luck on your consumption issue.
I found this an interesting article about the oil consumption issue and the fix.
[Modified by Gary2KC5, 5:05 PM 11/27/2001]
They dropped the engine out from the bottom, took about three days total. I do not recommend stopping by the dealer half way through the fix, not a pretty sight....
Be aware 1st though...IT IS NOT a pretty sight.
