Valve spring replacement How to
Old Dec 23, 2007 | 02:52 PM
2079's Avatar
2079
Default Valve spring replacement How to
Is there a how to on valve spring replacement ?
Do you still have to put compressed air in the cylinders to hold the valves up ?
There was mention of a tool that enables the removal of 2 springs in a single operation ?
Any pictures of this tool ?
Old Dec 23, 2007 | 03:49 PM
Last C5's Avatar
Last C5
If you're leaving the heads on you have to use either the compressed air or small soft rope stuck in the spark plug hole method to hold the valves in place while you change springs. Vincihiperformance.com had the Crane valve spring compressor on sale for $99. There are pictures of it on their site.
Old Dec 23, 2007 | 03:52 PM
vettenuts's Avatar
vettenuts
The tool you are looking for is made by Crane/VHP. VHP has the best price on it. As for holding up the valves, I prefer the TDP method which places the piston at the top and then you can do the valves on that cylinder. You need a way of ensuring the piston is at the top though. Once at the top, you can do two cylinders by following the firing order as there is always to pistons at the top at the same time. Here is the tool:
Old Dec 23, 2007 | 06:19 PM
2079's Avatar
2079
Again great info and super pictures vet .n ,greatly appreciated thank you for your replies
To Valve spring replacement How to
