camaro trans in a vette?
Old Dec 24, 2007 | 11:25 AM
GOGO-C's Avatar
GOGO-C
Default camaro trans in a vette?
Will a 4L60E from a 98 camaro work in a 98 vette ?
Old Dec 24, 2007 | 11:38 AM
GOGO-C's Avatar
GOGO-C
did a search and looks like it will work
Old Dec 24, 2007 | 04:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As far as I know NO it will not. The C5 trans is rear mounted and connects to the torque tube and rearend.
BC
Old Dec 24, 2007 | 04:41 PM
Mike Mercury's Avatar
Mike Mercury
BC
I wondered along those lines as well. do ya' suppose there's some sorta plate/mount/adapter on the Camaro/TransAm that fits the rear of the LS1 to the 4L60E tranny ???
Old Dec 24, 2007 | 06:44 PM
GOGO-C's Avatar
GOGO-C
I know this trans has a bolt on bell housing and looks like it will work. I dont know still.
Old Dec 24, 2007 | 06:46 PM
GOGO-C's Avatar
GOGO-C
also looks as if the tail housing were unbolted they look very simular.
Old Dec 24, 2007 | 09:35 PM
TraceZ's Avatar
TraceZ
Another thing to consider is the lengths of the input / output shafts.
Old Dec 24, 2007 | 11:22 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Without going into great details,it will NOT work. The differences are case,input shaft,pump stator support,shifter shaft lever,pan,etc.....
Old Dec 24, 2007 | 11:33 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats a wrap! If Rodney says it wont work,,,,take that to the BANK! FORGETABOUTIT! Its done,,,stick a fork in it!
He's the FORUM TRANSMISSION GOD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
BC
Old Dec 25, 2007 | 11:03 AM
Mike Mercury
why do they call it the same model number then ?
or is the C5 tranny a different part number than the Camaro/TransAm ?
Old Dec 25, 2007 | 12:05 PM
TLewis4095's Avatar
TLewis4095
The internal workings are basicly the same, but as Rodney points out...that is the end of it.
Old Dec 25, 2007 | 12:35 PM
Mike Mercury
I wasn't disagreeing; just curious as to why the part numbers are the same. I doubt that they are... how would GM differentiate between the two if the part numbers were the same ?
I'm thinking the "4L60E" is not the actual part number... just a series.
Old Dec 25, 2007 | 12:45 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
BC
This is correct and what it does is enables the Vette front to rear weight ration be in better proportion.
Equaling the superior handling we get from our Vettes!
GM had this is mind when building the C5 Vettes so that it be a superior product over it earlier years
Thanks,Matt
Old Dec 25, 2007 | 12:47 PM
Mike Mercury
Thanks,Matt
and adds rigidity to the frame (via the torque tube).
Old Dec 25, 2007 | 02:26 PM
Sick Z06's Avatar
Sick Z06
Correct. 4L60E, 4L80E, are series numbers by the respective manufacturers, NOT GM part numbers.
Old Dec 26, 2007 | 08:48 AM
99 vett babycar's Avatar
99 vett babycar
BC
Old Dec 26, 2007 | 02:36 PM
gpracer1's Avatar
gpracer1
I have a 4L60E in my 93 full size blazer.
Its just the model.
4 speed
L ockup converter
60 = the strength
E lectronic shift/valvebody
To camaro trans in a vette?
Old Dec 26, 2007 | 04:09 PM
Russ K's Avatar
Russ K
Actually, the "L" stands for longitude configuration (RWD). A 4T60E would be for a transverse configuration (FWD).
Russ Kemp
Old Dec 26, 2007 | 04:36 PM
BATM4N's Avatar
BATM4N
Just when I thought I knew it all, I realize I don't know Interesting info
Old Dec 26, 2007 | 05:30 PM
gpracer1's Avatar
gpracer1
Russ Kemp
I thought it was for lockup...
The 4L60-E derives its designation from its specifications: 4-speeds, Longitudinally positioned, 6000 lbs. GVW, Electronically controlled, although the transmission sees factory service in trucks up to 8600 lbs.
