weird problem from front end
Old Dec 24, 2007 | 09:06 PM
Vettegetsmwet99's Avatar
Vettegetsmwet99
Default weird problem from front end
i have a 2004 zo6 and i just installed new shocks about 4 months ago, my problem is when i turn the wheel sharp to the right or left, it feels like its bouncing and loose. the suspension also makes noise when im riding down the road, a popping noise.Im just wondering what it could be, could the shocks be causing this, or bad ball joints, or bad tie rods.
Old Dec 24, 2007 | 09:14 PM
double-oh-coupe's Avatar
double-oh-coupe
I've had the same problem for about nine months now ...
Old Dec 24, 2007 | 09:57 PM
lucky131969's Avatar
lucky131969
I'm assuming you have gone over all the mechanical connections i.e. :
bushing mounts, endlink connections, and shock hardware....
Old Dec 24, 2007 | 10:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is your car stock height and what shocks did you install? Blistens Shocks????? Thats whats in the sig.
BC
Old Dec 24, 2007 | 10:54 PM
Vettegetsmwet99
car is lowered about 2 inches, it has bilstein shocks just installed 3 months ago.
Old Dec 25, 2007 | 09:13 AM
VetteSiNz's Avatar
VetteSiNz
Need to re-torque all the mounting bolts.....thats' what I did when I replace all my suspension system (sway bars, springs and shocks). Hope this helps.
Old Dec 25, 2007 | 01:01 PM
lucky131969
So......have you visually inspected everything to make sure nothing is loose????
Old Dec 25, 2007 | 06:48 PM
Vettegetsmwet99
yeah everything looked to be tight, ill probably just take it apart and re torque all the nuts and bolts, something might have came loose
Old Dec 26, 2007 | 07:04 PM
Skinny Kid's Avatar
Skinny Kid
Mine does something similar, but only in slow speed situations. I've checked everything bolted down on the front end.... tight as a drum. I still don't know what's up.
Justin
Old Dec 26, 2007 | 07:25 PM
double-oh-coupe
Justin
Same thing with mine. Driving me nuts. I've visually inspected and re-tightened everything twice. Finally decided to just drive it till it breaks.
Old Dec 27, 2007 | 03:12 PM
FASST LN's Avatar
FASST LN
On another thread, someone mentioned a similar problem and apparently it was the tie rod and the nut was loose (or at least not as tight as it should be).
I have the same problem and mine started once I had an alignment done so I'm pretty hopeful this is the problem.
Old Dec 27, 2007 | 09:29 PM
rustyguns's Avatar
rustyguns
could be ball joints or inner tie rods...you cannot get to inner tie rods so that may be why everything feels tight. the passenger side inner tie rod goes out a lot in these cars !!!!!
you dont want to be driving it when that breaks!!! Crash!!!!
To weird problem from front end
