Rack & Pinion Question
Old Dec 25, 2007 | 03:19 PM
vredvet's Avatar
vredvet
Default Rack & Pinion Question
Dealer had to remove rack & pinion to install new cam bolts. Do you need to do a wheel alignment after this proceedure? Center of steering wheel is now off. If I center the steering wheel, car goes to the right badly. Do I need a wheel alignment or does the rack & pinion need to be adjusted? Thanks.
Old Dec 25, 2007 | 03:32 PM
lar66BB's Avatar
lar66BB
Default rack
If that is the case, I would say yes you need an alignment.
You should get the 4 corner alignment. That aligns the front
and the back.
Old Dec 25, 2007 | 04:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If this was an extended warranty repair,, Take it back to the dealer and raise hell. Tell them the car drives poorly ( It didn't prior to the repairs) and you think it should have been corrected with the original repairs. If you continue to drive it like it is, you will wear the front tire/s out in a New York minute!
If they wont cover it, find a GOOD alignment shop in town and have them align it.
BC
Old Dec 25, 2007 | 04:35 PM
randy814u's Avatar
randy814u
Also tell them the steering wheel is no longer centered. That is different then a alignment, and they need to deal with that.
Randy
Old Dec 25, 2007 | 06:29 PM
vredvet's Avatar
vredvet
Thanks Gentlemen! Merry Christmas!
Old Dec 25, 2007 | 07:04 PM
lucky131969's Avatar
lucky131969
BC
It's their responsibility. Make them fix it.
Old Dec 28, 2007 | 05:26 PM
BrianG01's Avatar
BrianG01
i bet the wheel was turned while the rack was out and they didnt notice when they re-attached it.
Old Dec 28, 2007 | 08:07 PM
Bill Dearborn's Avatar
Bill Dearborn
The replacement procedure calls for checking and adjusting the toe after installing the rack. It could be they didn't do this step correctly if at all.
Bill
To Rack & Pinion Question
