Driver side Headlamp down
Document ID# 338185
1998 Chevrolet/Geo Corvette
Headlamp Doors Inoperative - One Door
Headlamp Door Inoperative, One Side Step
Action
Value(s)
Yes
No
1
Were you sent here from the Headlight Door System Check?
Go to Step 2
Go to Headlight Door System Check
2
Disconnect the inoperative (left/right) headlamp connector.
Connect a DMM between the headlamp connector terminal A and terminal B.
Turn the headlamp switch to the ON and then the OFF position.
Measure the voltage at the DMM in both of the headlight switch positions.
Is the voltage within the specified values?
10.0-14.0V
Go to Step 11
Go to Step 3
3
Disconnect the headlamp opening door actuator control module connector C2.
Connect the positive lead of the DMM at the inoperative headlamp connector terminal B.
Connect the negative lead of the DMM at the headlamp opening door actuator control module connector terminal:
Left Side = terminal A
Right Side = terminal D
Measure either of the following circuits for continuity between the headlamp connector and the headlamp opening door actuator control module connector.
Left Side = CKT 576
Right Side = CKT 578
Is the relative circuit continuous between these two terminals?
Go to Step 4
Go to Step 7
4
Connect the positive lead of the DMM at the inoperative headlamp connector terminal A.
Left Side = terminal B
Right Side = terminal C
Left Side = CKT 577
Right Side = CKT 579
Go to Step 5
Go to Step 8
5
Connect the negative lead of the DMM to ground.
Measure either of the following circuits for continuity to ground.
Left Side = CKT 576
Is the relative circuit shorted to ground?
Go to Step 9
Go to Step 6
6
Left Side = CKT 577
Go to Step 10
Go to Step 12
7
Repair a poor connection or an open in the circuit relative to the inoperative headlamp door.
Left Side = CKT 576
Is the repair completed?
8
Left Side = CKT 577
9
Repair a short to ground in the circuit relative to the inoperative headlamp door.
Left Side = CKT 576
10
Left Side = CKT 577
11
Replace the inoperative headlamp opening door assembly.
Is the repair complete?
12
Replace the headlamp opening door actuator control module.
