got some new codes. help?
Old Dec 27, 2007 | 04:24 PM
99FRC Newb's Avatar
99FRC Newb
Default got some new codes. help?
P1111
B0516
U1096
U1064
U1016
all history codes.
can anyone tell me what they mean?
Old Dec 27, 2007 | 04:29 PM
lucky131969's Avatar
lucky131969
http://www.aceesolutions.com/vette/1999dtc.html
Old Dec 27, 2007 | 04:38 PM
99FRC Newb's Avatar
99FRC Newb
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC B0516 Speedometer Signal Circuit Malfunction
DTC U1016 Loss of Communications with PCM
DTC U1064 Loss of Communications with BCM
DTC U1096 Loss of Communications with IPC
wtf? i'm really confused now! wouldn't some of these throw on my MIL?
Old Dec 28, 2007 | 01:06 PM
j84buick's Avatar
j84buick
Throw on your MIL? Do you mean DIC? Not sure what you mean there.
The "Loss of Communications" codes are pretty common. I always have them in my history after a few drives even after I cleared them. I posted awhile ago about them and the opinion was not to worry about them.
Old Dec 28, 2007 | 01:36 PM
vincentjames501's Avatar
vincentjames501
Sounds like a battery problem to me.
Old Dec 28, 2007 | 01:42 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Originally Posted by 99FRC Newb
P1111
B0516
U1096
U1064
U1016
all history codes.
^^If they are history codes that means they happened in the past. Noting to worry about. Reset them and see if any current codes come up. If nothing comes up no worries.
Someone may have done some work on the car, which included disconnecting the battery and that caused the codes.
Old Dec 29, 2007 | 07:41 AM
99 vett babycar's Avatar
99 vett babycar
the computers always loose communications. if its all H codes just clear them its SOP
Old Dec 31, 2007 | 09:05 PM
99FRC Newb's Avatar
99FRC Newb
i had cleared my codes a week before.
haven't had any battery problems.
MIL=Malfunction Indicator Lamp (Check Engine Light)
Old Jan 1, 2008 | 03:12 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Mine(2000) has PO113 and P1111 which are both IAT hi voltage related. The Check engine lite stays on...Clear the codes and the lite stays out for a few minutes and comes back on...How do you fix it???
Old Jan 1, 2008 | 03:16 PM
lucky131969
nice thread hijack
Old Jan 1, 2008 | 04:58 PM
DeeGee's Avatar
DeeGee
With those codes sounds like you've had a power spike or maybe the battery starting to go bad.
I'd reset them and see if any come back. You can safely ignore the U codes but the other 2 may reoccur but maybe not.
To got some new codes. help?
