Head Question
With a h/c combo, would I be laying down bigger numbers/ quicker et's with a set of ported PRC 243 stage 1 ls6 heads, or a set of AFR 205 milled to 62cc? I've been told that with the PRC's I could go with a bigger duration/lift cam than if I went with the AFR's.. I've been impressed with the flow #'s on the AFR's, but it looks to me that the PRC's would have more lowend torque.. My buddy is telling me he'd give me his PRC heads for $600 bucks... I was just curious what you all had to think regarding these setup options.
If the PRC's aren't milled, and you use a stock thickness head gasket, you should be able to fit them without having to notch the pistons.
The AFR's may or may not fit w/o notching. There seems to be a lot of conflicting info out there about p/v clearances with AFR heads. Tony Mamo will likely tell you anything bigger than low 230s duration isn't gonna fit, but LG will tell you the X4 will clear with 59cc AFR 205s and a .040" gasket. Honestly, I can't tell you who's right, or what "it'll clear" really means to the people claiming it. Anyways, if you find they don't clear...be ready to spend more money to cut the pistons.
The X4 is a big cam (mid 240s duration), and with stock heads/stock gasket, you probably are only seeing about .050" clearance to the intake valve.
Most people will recommend a minimum of .080" clearance to the intake valve, and .100" clearance to the exhaust. When you get into custom heads, remember milling, bigger valves, thinner gasket, etc will further reduce that clearance. That's why I said the stg1 PRC's should fit if they aren't milled, since they use the stock dia valves, and if I recall, the valve seats may be sunk a little deeper too (for additional clearance).
I am running the X4 cam, with 59cc TEA stg 2 ported 5.3l heads with bigger valves and .040" head gaskets. This is about the limit for compression on 93 octane (I"m at 11.7 scr / 8.6 dcr) I also notched the pistons .100" deep to achieve adequate intake valve clearance. (Sorry, no dyno #s or track times yet). With 62 or 64cc heads...your compression definitely won't be too high. Not with that cam...
Personally, for what you want (1/4 mile - where hp is everything and lowend tq not so much a concern)...if money was no object, look into the small bore AFR225s, Trickflow 215s, or ETP 225s... mill them down to 59-61cc for best compression, and notch the pistons if needed. Add a ported FAST 90 setup, and expect a 500rwhp beast that will pull hard to nearly 7500rpm.
I talked with Tony Mamo and will be ordering a ported fast 90 with a ported ls2 tb. That'll put the following mods on the car
-Mamofied 90/90, LG Pro's, xpipe/borla cb, honker(may switch to vararam), U/D pulley, textralia, DR's..
I've been reading a lot of different threads discussing PTV/ flycutting pistons, etc.. To avoid some of these issues and attaining clearance I'm looking at this setup. G5X4, AFR 205's 61cc, and the stock head gasket rather than the cometic .040" Let me know what you all think about this combo.. and thanks guys for your responses, they've been more than helpful!
If anything, for the OP's stated goals, he should be looking at the smallbore AFR 225s for that cam and application.
As has been claimed by LG on LS1Tech, even 59cc AFR's have more valve drop (clearance) than than 100% stock GM heads.
Your Dart's on the other hand, start out with less valve drop than stock heads.
You have to understand that aftermarket heads are not all the same. You can't rely on just a chamber size to tell you how much clearance you'll have, or what will clear, as you have no idea how far up in the chamber those valveseats are placed.
Valve drop...seems counter intuitive more valve drop = less clearance. Running 10s with a 224/228 cam is indeed very possible. Good set of heads, intake, headers, 3.73s (event 3.42s), 3600 stall (assuming an A4), sticky tires, and, of course, a 125hp shot of the juice and I guarantee your in the 10s...I plan to be anyway.
Valve drop is a measure from the valve at rest in it's seat, to the deck surface of the head. It is simply a measure of how far up in the chamber the valveseat is located.
Take a head with no springs in it, put it chamber side down on a table. Hold a valve up in it's seat. Then let it drop down until it hits the table. The distance the valve moved is known as valve drop.
More valve drop = the valve is higher up in the chamber, and therefor, starting it's travel further away from the piston, it will always have more p/v clearance than a head with less valve drop.
I've got them and they are great! I made with my H/C set-up 423 RWHP and 399 RWTQ!
See the sig below!
Thanks,Matt
ok, I guess you don't know what valve drop means.
They seem to have good flow numbers
