Cam ??
Old Dec 30, 2007 | 10:25 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Default Cam ??
I was woundering if this is a smaller or mid size cam ( Comp Cam 228/222 .588, .581 lift 114.5 LSA )?
Old Dec 30, 2007 | 11:21 PM
black98c5's Avatar
black98c5
I would say it's more on the smaller side but then again I have a cam in the 238/242 range. If your trying to figure out if drivability would be effected, you should retain stock-like drivability with that cam with a slight lope. If you want a little comparison to the cam you mentioned, the cam in your car now is a 204/218 551/541 117.5lsa .
I suggest you read this to get a better understanding of cams and what the numbers all mean.
http://ls1tech.com/forums/showthread.php?t=327734
Old Dec 31, 2007 | 08:51 AM
vettenuts's Avatar
vettenuts
Not sure why are you considering a reverse split (exhaust duration lower than intake).
Old Dec 31, 2007 | 09:43 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Looking for more HP. So I am thinking of putting a bigger cam in.
Old Dec 31, 2007 | 10:01 AM
vettenuts's Avatar
vettenuts
In general terms, the LSx likes to have equal or more duration on the exhaust side.
Old Dec 31, 2007 | 11:47 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I would say it is in the middle range--there are many cams availiable that have less duration and more LSA than that--As mentioned above--i'd be sure about the "reverse split " type as well--unless you were specifically recc. this cam by your builder--i would pick a more conventional type--Also--if you are in an Emisions state that uses the snifter test be careful when going above .224/.224 with a 114 LSA--it will be borderline in passing
Old Jan 1, 2008 | 08:32 AM
AU N EGL's Avatar
AU N EGL
a reverse split wont get you more HP, it will give you more under the curve torque. but the 114 LSA negates that.
I run a comp cam 224/224 .581/.581 112, which is a good cam, but not that big. just over 400 rwhp & toruqe when tuned last winter.
If you want more HP, go with a bigger cam. LG G5X2 for example
change your underdrive pully too.
Old Jan 1, 2008 | 08:40 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, in general as AU N EGL says
Old Jan 1, 2008 | 10:04 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Here is my set up. I am trying to get to the 450+. I don't know if I want a ported fast intake, or to put a bigger cam in...
I love the set up, but would love to get a little more out of it.
429 rwhp SI007 cam 228/222 .588, .581 lift 114.5 LSA , RGR Stage 1 LS6/243's, ( STOCK VALVE ), Comp 918's, Comp Pushrods, Taylor wires, ARP head bolts, SLP Crank Pulley , Port Matched LS6 intake, Raptor XXL and air bridge, SW LT's with no cats, B&B prt catback, Delphi 38# inj. , 3.90 gear (stock rear),
Old Jan 1, 2008 | 10:07 AM
AU N EGL's Avatar
AU N EGL
450? Ported FAST90/90, with LG G5X4 will get you there.
Old Jan 1, 2008 | 11:15 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Is that not a big cam? I thought that I would be o.k. with the G5X2.
Old Jan 1, 2008 | 01:12 PM
AU N EGL's Avatar
AU N EGL
G5X2 232/240 595/608 112
G5X3 234/242 600/610 112
G5X4 240/244 low 600s 111
432rwhp 406 rwtq G5X-2 cam and LG Pro LT Headers, ported LS6 heads
To get more then you have ( 450+) you will need to go to a BIG cam, or big cubies
Old Jan 1, 2008 | 04:07 PM
zeevette's Avatar
zeevette
Or better heads. My cam's only 228-232, and I have WAY over 450RW.
Old Jan 1, 2008 | 04:12 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm running a G5-X2 on a 114 lsa, making 436 rwhp and 397 rwtq through stock LS6 heads and boltons.
Old Jan 1, 2008 | 06:35 PM
AU N EGL's Avatar
AU N EGL
Yes AIR flow is a huge key here. Not all PP 243s are the same. and were do you want the power?
To Cam ??
