Traction problem
Old Nov 27, 2001 | 04:45 PM
Sally's Avatar
Sally
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Traction problem
Just recently I am having a problem with my 2000 coupe's traction. I have a manual transmission, and when I start hard from a stop or slow roll the backend hops around instead of sticking like it use to. What do you think the problem is?
Old Nov 27, 2001 | 04:56 PM
yellow01's Avatar
yellow01
Default Re: Traction problem (Sally)
This might sound like a dumb reply, but has the weather gotten significantly colder?
I can definitely say that my tires break loose EASILY in 50/60 degree weather, but not so easy in 80+. You can definitely feel the power difference.
Traction also changes significantly on cold tires/pavement.
Old Nov 27, 2001 | 05:42 PM
pewterhdtop's Avatar
pewterhdtop
Default Re: Traction problem (yellow01)
I noticed the same problem, last night going to get gas a Honda Rice A Roni pulled up next to me. Since he put the gas to it, I just had to open the car up. Spun the tires from a roll for about 20 feet. It was colder, approx. 40 degrees F out, and my rear tires are almost shot. I also think they use a harder compound rubber closer to the belts, so it would follow that they should not hook up well in the cold. :cheers:
Old Nov 27, 2001 | 06:00 PM
VetteDrmr's Avatar
VetteDrmr
Also, as tires get older and go through more and more heat cycles they get harder and stick less. The tires that were on my Z when I bought it were so hard it was almost dangerous to drive (like perpetual wet conditions) even though there was plenty of tread depth left.
Have a good one,
Mike
Old Nov 27, 2001 | 06:09 PM
RedLandRocket's Avatar
RedLandRocket
Default Re: Traction problem (VetteDrmr)
I had a similar problem this morning. 50 degrees, rainy, driving about 40 downshifted to first, hit the brakes to make a right turn, ABS Active came on the DIC and the back wheels started hopping. I have on GY EMT's and the back are about 70% worn.
Old Nov 27, 2001 | 09:04 PM
Dave H's Avatar
Dave H
Hi: A temperature problem I think. In the summer I've got to work at breaking them loose but from about 50 degrees on down I have to be careful not put it sideways when powering out of a corner. Also can spin 'em fairly easily on aggressive acceleration. See the TC DIC message a whole lot more in the winter. :D :D :D
Old Nov 27, 2001 | 09:13 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Cooler weather bring more hp and torque causing the wheels to break loose easier.
[Modified by wallstAL, 5:15 PM 11/27/2001]
Old Nov 29, 2001 | 02:10 PM
Sally's Avatar
Sally
Cruise-In I Veteran
Default Re: Traction problem (wallstAL)
Thanks for all the input. The tires are pretty new, so I am sure that it has little or nothing to do with the tread. And, 50 degrees didn't seem that cold to me. However, it is a fact that I haven't driven the car with these particular tires in this weather. I never had this happen before with the car, and I have driven it over 45,000 miles. I'm still not sure that there isn't something wrong.
To Traction problem
