Teach me about TPS units
Old Jan 3, 2008 | 04:28 PM
drivestwin's Avatar
drivestwin
Default Teach me about TPS units
I am curious about how the entire system works.
Power supply? How does the car know which is LR, RF etc? How are they mounted?
Teach me all you know about the units...would just like to know more.
Old Jan 3, 2008 | 04:36 PM
DeeGee's Avatar
DeeGee
The TPS straight out of the box is just a battery powered RF transmitter. It uses the cap on the tire valve as an aerial and transmits the pressure reading to the onboard receiver situated in the reardrivers side fender area. Once the receiveer picks up the signal it tells the PCM the reading and its displayed on the DIC. The receiver is shared with the keyless entry system.
To save the batteries (lifed at 7 years or so) the TPS goes in hibernation when the car is stationary. It only transmits a signal after the car has been moving for 20 secs or so hence the lag on the system.
Once fitted, you train the TPS in the sequence ordered by the DIC to tell it where on the car it sits.
The tire valve is integral to the TPS which is held in place by a nut on the outside of the rim and made leakproof by a rubber O seal
Old Jan 3, 2008 | 06:08 PM
Bill Dearborn's Avatar
Bill Dearborn
Each TPS unit has its own unique identification so when the car tells you to program the LF wheel all you are doing is using a magnet to turn on the transmitter. The car then learns that transmitters code and stores it as the LF wheel. If the wheel is moved to another location on the car the car and the module do not know that and the pressure reading will will still show LF although the tire is on the RF. You cannot reprogram to get the module to correct erroneous pressure readings (other than where it is located) the only way to do that is to replace the module.
Bill
Old Jan 3, 2008 | 06:29 PM
TheLegacy81's Avatar
TheLegacy81
excellent info guys. Thank you for the thread and the posts. Definitely helps a rookie like myself understand the unit a bit better.
Old Jan 3, 2008 | 07:13 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Good explanations above!
Old Jan 3, 2008 | 07:23 PM
mathia's Avatar
mathia
I've seen references to the fact that the TPS for '97-'00 cars are different from the '01-'04 cars. Can anyone verify that and/or explain what changed?
My '01 threw a service tire monitor warning on the DIC the other night for about 5 minuts and then returned to normal. I think I read the batteries are only good for about 6 years, so I'm thinking I probably have weak batteries. I'm about to put on a new set of tires so I want to get new batteries in the TPS then. Can I replace the batteries in the TPS's or do I have to get new ones?
Old Jan 3, 2008 | 07:28 PM
Oldvetter's Avatar
Oldvetter
They do NOT use "the cap on the tire valve as an aerial". The antenae is actually in the TPS body.
Old Jan 3, 2008 | 07:35 PM
BlackZ06's Avatar
BlackZ06
The key to the system is the Remote Function Actuator (RFA) which is the radio receiver located in the rear behind the driver. This receiver picks up signals from your key fobs (LOCK/UNLOCK, etc) and the signals from the TPMS located in the wheels.
For the 2001 Model Year Chevy changed the radio frequency that the RFA monitors, so the key fobs and TPMS in the 1997-2000 transmit on a different radio frequency than the 2001-2004 fobs/TPMS use. That's why there is no way the fobs/TPMS can be interchanged between the two systems.
I strongly suspect that those who have a 1997-2000 could install the "new" RFA from a 2001-2004 and switch to the much cheaper 01-04 TPMS and key fobs. Wiring is the same for both RFA, and it appears that the IPC would not notice the difference in the transmit rates between the two TPMS systems.
Old Jan 3, 2008 | 07:41 PM
mathia's Avatar
mathia
Thanks for the info! Anybody know if the two versions of the TPS use the same type of battery? I've found some threads linking to a page on how to change the batteries, but the site is being redone and the link doesn't work right now. Here it is in case they fix it:
http://www.cccorvetteclub.org/tps_replace.htm
Old Jan 3, 2008 | 07:52 PM
BlackZ06's Avatar
BlackZ06
Since you have an 01, you use the "cheaper" TPMS .... so I'd just order new ones.
Part numbers should be ....
25773946 - sensor
15234846 - nut
Order 4 of each .... should run about $180.00 total, check the supporting parts vendors for prices ....
Old Jan 3, 2008 | 09:27 PM
drivestwin's Avatar
drivestwin
Thanks for all the great information. I sure like to try and understand how my 99 works. Every little bit we can learn is that much better.
Old Jan 3, 2008 | 11:46 PM
Corvette Don's Avatar
Corvette Don
Nope, the actual valve stem IS the antenna
Old Jan 4, 2008 | 01:01 AM
SLO VETTE's Avatar
SLO VETTE
You'll need to refer to the TPS Reports.
Didn't you get the memo?
Old Jan 4, 2008 | 01:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture of a 2001+ TPS mounted on a chromed ZO6 OEM wheel:
The valve stem IS NOT the antenna! If you "band mount " the TPS, you can rip off the valve stem and it will still work and program normaly:
pics27.jpg[/IMG]
Here are pictures od an EARLY and LATE model TPS ( the early model TPS is the one on the RIGHT)
Old Jan 4, 2008 | 02:01 AM
RoccoC5's Avatar
RoccoC5
They must be pretty light, so as to not require a bunch of wheel weights to offset them, yeah?
Old Jan 4, 2008 | 02:59 AM
DeeGee's Avatar
DeeGee
Thats true, the antenna is in the body.
Maybe it's one of those Old Wives Tales. I was told by someone I had no reason to doubt, that the reason we had metal caps is that it acts as a re-radiator for the TPS signal. Kind of like a cheap amplifier. To that end, he said you should always use a metal cap (radiator) not a rubber cap (insulator).
I'm sure you're correct - probably
Old Jan 4, 2008 | 04:10 AM
mathia's Avatar
mathia
25773946 - sensor
15234846 - nut
Yeah, but if I can replace just replace the batteries I think it would cost around $20. I found this link which states a source for new batteries, but it only mentions the '97-'00 version: http://c5help.com/tps_replace.htm
I'm guessing since I haven't found any docs talking about replacing the batteries on the '01-'04 version, it can't be done
Also, do you really need a new nut? Why can't you just reuse the originals?
To Teach me about TPS units
Old Jan 4, 2008 | 07:26 AM
drivinhard's Avatar
drivinhard
Old Jan 4, 2008 | 12:02 PM
Corvette Don
I have had these completly apart and it looks like it uses the valve stem as part of the antenna but I could be wrong (hence the magnet around the valve stem to program) I have programmed them with a decent magnet (4" x .5") about 2-3 inches AWAY from the end of the stem and it will program but that could just be due to the fact that its a strong magnet.
They are really light, it wont require a lot of weight to balance at all.
The 01-04 sensors are cheap new so its not really worth rebuilding them although I do want to try those, you do not need a new nut, I just tell ppl to re-use theirs and I have never had a problem. And those batteries DO NOT work for the 97-00 sensors, the tabs on them are not long enough!!
Old Sep 23, 2008 | 06:27 PM
msu-dawg's Avatar
msu-dawg
BlackZ06- were you ever able to confirm that this swap works?? I've got some wheels with tires and 04 TPMS sensors (already mounted) on the way and I need to order the 01-04 style RFA but would really like to confirm it'll work before I cough up more coin.
