AC not working right
No joke. You would think it would be a damper door or something, but a little low on freon can cause cool air only on one side.
On a more serious note, Yep,,,,check the DTCs for any HVAC DTCs. If you have them try this procedure:
Turn the HVAC System OFF.
Pull up the DTC and scroll down to HVAC and check for DTCs Write down the listed DTC and then clear them. When you clear them you will hear the HVAC actuators cycle through their full ranges. Once they stop, turn on the HVAC and see if the problem is resolved. If NOT, repeat this procedure a number of times. I had to do it 5-6 times and since then,,I have been code and trouble free!!
The actuators will NOTwork if you have actuator failure DTCs.
If you cant clear the DTCs after trying 5-6 times, the actuator/s could be bad. The gear on the output shaft splits!
If you DONT have DTCs ,,,YEP, check the R-134A level.
BC
BC
I've added the refrigerant twice before (with in the last 9 months) when the system was not cold. I suspect I have a small leak somewhere. But the question remains... Why now only the driver's side....?
Since then I have seen dozens of posts just like yours that proved the opposite. I am now a believer but I still can't explain it. I even showed the evidence to a friend of mine who is an AC guru (maintains several thousand tons of AC) and he said "Doesn't make any sense to me".
Perhaps others can explain this better than I. At this point I'm just going to file this in the big folder titled "Stuff I know how to fix but don't fully understand".
100% Correct! You posted a few minutes before I did and I was going to explain it in a similar way!
When the pressure and R-134a is low, the sprayed R-134a runs out of heat absorbing capacity somewhere in the middle of the evaporator, (leaving the passengers side warmer than the drivers side) and the liquid R-134a is transfered completely to a gas which cant absorb any more heat from the cooling coil tubing.
Thats my theory and I'm sticking to it!
