Lumbar controls issue - tech help?
Old Jan 6, 2008 | 10:40 PM
Spirited Cat's Avatar
Spirited Cat
Default Lumbar controls issue - tech help?
I tried to find a thread on this, but I did not see one with this particular issue. I also posted this in the General Section and got zero replies. Please comment if you can.
The lumbar controls normaly inflate and deflate when the buttons are pressed with the sound of the compressor operating. The compressor sound also is heard when deflating the bladders and apparently forces the air out. Trouble is, the inflate buttons work fine, but when deflating, nothing happens. No compressor noise or deflating. If I press on the bladders, while holding the button in the deflate direction, the bladders will deflate.
I am electronically capable so I imagine a relay is not working or an wire is disconnected or broken. I have taken the seat loose enough to see everything under the seat, but can not locate the problem.
Does anyone have a schematic or interconnection diagram or any knowledge on the subject I can use to track down the problem.
Thanks for any help you can provide
Old Jan 6, 2008 | 11:02 PM
LV,99LS1VERT's Avatar
LV,99LS1VERT
I am having the same problem,but dont know what the problem is either Mine work sometimes and sometimes they don't.I'm going to pull the seats and look,but I'm sure what I am looking for
If you find the problem LMK Thanks Joel
Old Jan 11, 2008 | 08:53 PM
Spirited Cat
I will let you know what I find, I plan on getting into it again this week end ... looking kinda bleek on the CF support line ...
Old Jan 12, 2008 | 03:19 AM
DeeGee's Avatar
DeeGee
Have to say thats a new problem. I've heard plenty where the motor quits or the bladders/pipework leak. To have the problem on just deflation is a new issue to me. From a quick look it would seem that the snag has to be within the seat pump. Is fuse #3 good, although that seems to control both inflation and deflation?
Heres the schematic. BTW, I managed to chop off the ground. It grounds at G205. Post up and let us know how it goes.
Old Jan 12, 2008 | 04:11 PM
RED95CONVLUVER's Avatar
RED95CONVLUVER
I was also having lumbar support issues on my 2000. The motor was running with no results. After pulling seat and pump ive discovered the motor/pump itself is bad. A new one at GM is $485. Anyone know where else to look for one? Used is fine with me. Thanks
Old Jan 12, 2008 | 04:29 PM
DeeGee's Avatar
DeeGee
Try one of the Forum Vendors
Gene Culley at GM Parts House
or
Bob at Fichtner Chevrolet
The links are down the left of the Board
Old Jan 24, 2008 | 10:44 PM
Spirited Cat
DeeGee .. just got back to this thread, sorry it took so long - This schematic is GREAT - thanks, I should have the answer this weekend ...
To Lumbar controls issue - tech help?
