Will this get 500HP ?
Old Jan 8, 2008 | 04:59 PM
steinbergum's Avatar
steinbergum
Default Will this get 500HP ?
Iam looking at a 2002 Z06 that has installed this parts:
As far as performance parts it has SLP long tube headers , borla XR-1 racing exhaust, Vararam intake, WWC air bridge, Modified MAF sensor, TPIS air foil, and MSD wires
The seller are telling me that the car will produce 500HP, will it ??
Thanks for replay !
Old Jan 8, 2008 | 05:06 PM
BigSexy181971's Avatar
BigSexy181971
Default Not
I would have to say no. That is alot of extra power for only those bolt ons but I am sure that others will let you know what they have with their similar combo's.
Old Jan 8, 2008 | 05:07 PM
chaase's Avatar
chaase
St. Jude Donor '12
Thanks for replay !
nope....I would guess around 450hp
Stock: 405hp
Vararam: 10-15hp
LT Headers w/Exhaust:30-35hp
Air Bridge: 0hp
MAF: 0hp
Wires: 0hp
TPS Air Foil: 0hp
total: 445-455hp
Old Jan 8, 2008 | 05:37 PM
lucky131969's Avatar
lucky131969
Thanks for replay !
Not even close.
Old Jan 8, 2008 | 05:49 PM
miami993c297's Avatar
miami993c297
Stock: 405hp
Vararam: 10-15hp
Air Bridge: 0hp
MAF: 0hp
Wires: 0hp
TPS Air Foil: 0hp
total: 445-455hp
405 hp = ~355 RWHP
450 hp = ~391 RWHP
500 hp = ~435 RWHP
And with the mods mentioned by the OP, no way to be there...ask for the dyno sheet SAE Corrected.
Christian
Old Jan 8, 2008 | 06:54 PM
black98c5's Avatar
black98c5
Originally Posted by lucky131969
Not even close.
Old Jan 8, 2008 | 07:07 PM
YeloFevr's Avatar
YeloFevr
What are you guys talking about?! That MAF is good for at least 40 rwhp!
Old Jan 8, 2008 | 07:14 PM
B-Vette's Avatar
B-Vette
Stock: 405hp
Vararam: 10-15hp
Air Bridge: 0hp
MAF: 0hp
Wires: 0hp
TPS Air Foil: 0hp
total: 445-455hp
You would also require some sort of tuning to even maximize these additions.
Old Jan 8, 2008 | 07:19 PM
red88L98convert's Avatar
red88L98convert
the vararam won't add ANY hp until you are going 45mph, hence the 'ram' part of the name.
Old Jan 8, 2008 | 07:29 PM
99 vett babycar's Avatar
99 vett babycar
not even close
Old Jan 8, 2008 | 07:30 PM
miami993c297
Thanks for replay !
Hi steinbergum,
With the stock camshaft and valvetrain it's almost impossible to go over 385 RWHP or 440 hp+...
And you need an extremely well done tune to achieve those numbers!!!
Christian
Old Jan 8, 2008 | 08:17 PM
lucky131969
Hmmmm.....I forgot about that. Perhaps a performance hood seal would get you closer to 500hp.
Old Jan 8, 2008 | 08:35 PM
cruisemon's Avatar
cruisemon
CRAP. Beat me to the hood seal mod.
and NO WAY does this make anything in the same zip code as 500 hp. If it did, there wouldn't be a 427 LS7 engine. Now granted the only way the Z06 engine makes less than close to 520 hp at WOT is with the ignition shut off. A source tells me it is not that unusual for some of the LS7's to make close to 550 hp. That said, the LS6 needs more than some slap ons to make the power they're claiming.
Tell you what - tell the seller that you want to take the car to a dyno and if it makes 495 hp or more you'll pay them $5,000 more than they're asking. If it makes less than 475, they'll come down $5000 off the asking price. Here's a hint - if they agree, you'll save yourself 5 grand.
Charlie
Old Jan 8, 2008 | 10:43 PM
C5B's Avatar
C5B
I am sure the seller means 500bhp, but still..... no way.... not even close. As others have said: 440-450 is about it at the crank..... if he's lucky. Dyno will be nowhere near 500.
- Colby
Old Jan 9, 2008 | 01:56 AM
lucky131969
Ask the seller where he got the car tuned so you can have a peek at the dyno sheet.
Old Jan 9, 2008 | 02:16 AM
BlackZ06's Avatar
BlackZ06
500 HP with those mods ??????
I'd ask the seller what he smokes, and buy that from him, rather than the car ....
Old Jan 9, 2008 | 02:54 AM
lucky131969
To Will this get 500HP ?
Old Jan 9, 2008 | 08:29 AM
gdphillipsvette's Avatar
gdphillipsvette
He's a liar...
Old Jan 9, 2008 | 08:55 AM
AU N EGL's Avatar
AU N EGL
500 HP with out PP heads and big cam? Not likely
Old Jan 9, 2008 | 09:23 AM
TripleBlack98's Avatar
TripleBlack98
No way!! Check my sig. with all my mods and see what I laid down.
