Cat's a rattlin?
Old Jan 8, 2008 | 05:10 PM
Vette Rookie's Avatar
Vette Rookie
Default Cat's a rattlin?
One of the catalytic converters on my 97 is rattling and I'm looking for replacement solutions. Will the H-pipe off of a 03 Z06 be a direct replacement or would I need the exhaust manifolds from the Z06 also? Are the O2 sensors in the same place? I know that there is a difference between the 97-00 and the 01-04, just not sure to what extent they change. TIA
Old Jan 8, 2008 | 06:31 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Replace it with another OEM converter
Old Jan 9, 2008 | 05:05 PM
Vette Rookie
Can you replace a single cat or does it come as a complete assembly with the "H" pipe?
Old Jan 9, 2008 | 05:26 PM
berryj's Avatar
berryj
Check w/ Gene at www.gmpartshouse.com
I'm pretty sure you can buy them individually. A local exhaust shop can weld them on for you.
To Cat's a rattlin?
