Underhood Fuse panel connections?
Old Jan 12, 2008 | 08:30 AM
busta's Avatar
busta
Default Underhood Fuse panel connections?
Anyone have any pics or diagrams of the connections that connect to the under hood fuse panel? Not the 3 Block connectors but there is a spot for about 5 2 pin connections.
This is for a stock 2002 automatic tranny.
Old Jan 12, 2008 | 10:48 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You should post info of year and tranny type as the wiring is different, between years and tranny types.
Old Jan 12, 2008 | 11:33 AM
busta's Avatar
busta
Default Underhood fuse panel wiring? 2002
doh i added the details to my original post it's a 2002/auto that I'm looking for info on...
Old Jan 12, 2008 | 11:38 AM
DeeGee's Avatar
DeeGee
The service manual shows 3 connectors at the back of the Underhood Electrical Center (the engine wiring harness, the IP wiring harness and the forward lamp wiring harness). Are they the ones you mean? They're multi pin connectors though
Old Jan 12, 2008 | 11:46 AM
busta's Avatar
busta
No, I have those multi pin connections those are the 3 block connectors I was talking about. There are 3 or 4 smaller 2 spade connectors they look to be heavy gauge connections. They're keyed connectors I have on Red wire that fits but not sure what goes to the other connections.
This is for something I'm building so it is possible I'm missing something. I have both stock engine harness and dash harness that are correct for a 2002 but not the car itself. I was thinking one might be a ground?
Old Jan 12, 2008 | 12:34 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Post a picture.
Old Jan 12, 2008 | 12:56 PM
busta's Avatar
busta
Default pic of fuse panel
here is pic of fuse panel i put yellow dots next to the connectors I'm wondering about...
Old Jan 12, 2008 | 01:31 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
They are Maxi Fuse Locations;
Some are used and some are blank position are not. You would have to have something that draws a lot of power like a defroster or blower motor to use those.
Go to this website and down load fuse layout.
http://www.davidfarmerstuff.com/
To Underhood Fuse panel connections?
