Replace one injector or all?
Old Jan 14, 2008 | 08:22 AM
cruisemon's Avatar
cruisemon
Default Replace one injector or all?
Changed plugs on my car, 93K miles, and plug colors were dark brown as expected except for number 8 cylinder. It was white with a tannish hint. I interpret this as this cylinder running leaner than the others and think the only thing that could cause that would be an injector that is dirty and flowing a tiny bit less fuel than the others.
Does this sound like a correct diagnosis?
If it is, can I replace a single injector (same OEM part number as others) or should I replace all of them? I am pretty sure replacing an OEM injector with an aftermarket unit or maybe even a later model OEM that ostensibly flows the same rate but has a different part number wouldn't be a good idea.
The car is a daily driver and I do not thrash it hard enough to tax the stock injectors, so a higher flow aftermarket injector wouldn't be of benefit.
What do you think?
Charlie
Old Jan 14, 2008 | 10:43 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Send your injectors out to be cleaned & flow tested, it should only take a couple of days to send them out and get them back.
Old Jan 14, 2008 | 11:58 AM
dougbfresh's Avatar
dougbfresh
Agreed, you can have them ALL cleaned and flow tested for less than the price of 1 new injector. Check out www.cruzinperformance.com
To Replace one injector or all?
