In Dash Rattle......uuugh!!
Old Jan 14, 2008 | 07:57 PM
red88L98convert's Avatar
red88L98convert
Default In Dash Rattle......uuugh!!
98 A4. I have a rattle in the dash, sounds kind of 'deep' and centered, but not right behind the radio or heater controls. It started a couple of months ago and around the same time, the heater stopped blowing hot air.
I just did the dim hvac display fix and while it was apart, couldn't see anything loose.
It may be further back in the dash. Are there any vacuum check valves or anything back there that could be rattling? It seems like since both happened at the same time, (rattle beginning, heater not blowing hot air) that they would be simptoms of the same problem.
How do I get access back there? When I had the radio and hvac controls out, there were metal brackets that everything bolted into and I couldn't see behind them.
Any help?
Old Jan 15, 2008 | 01:24 PM
red88L98convert
i can't believe NO ONE has had a rattle in thier dash........
Old Jan 15, 2008 | 02:29 PM
mcgilles's Avatar
mcgilles
I do! on rare occasions. first started after a 30 minute drive down a cobblestone road. it only happens from time to time, but it is annoying. I have no idea what's causing it, I haven't taken anything apart yet. let me know if you ever figure it out!
Old Jan 15, 2008 | 03:19 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I have one too.It started conveniently enough just after this last smog check.I have a hunch it has to do with the obdII port in some way he plugged into.It only happens when car is cold.
With my neck in the shape it is in right now,I haven't got in there to take a good look.
Rattles can be a great source of anguish
I wish I could be of more help,but you are not alone...
Old Jan 15, 2008 | 06:01 PM
red88L98convert
well, i was hoping someone had done something about this on thier car already.
i guess i'll have to tear it down when the weather warms a little. once i start driving it regularly again it'll drive me nuts.
Old Jan 15, 2008 | 06:29 PM
flynbya2's Avatar
flynbya2
Just a heads up,which may help,but there is a section in the 3 volume shop manual dedicated to squeeks and rattles I stumbled across at one time.
If you have them,maybe that is a good place to start
Old Jan 16, 2008 | 08:03 PM
red88L98convert
nope, no manual...anyone out there that can look that up for me???
Old Jan 16, 2008 | 08:20 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I had a rattle in my dash so I sold my Pontiac. Now I have a buzz in my dash but I need my Ford for daily drivin'!
Old Jan 17, 2008 | 12:25 AM
Baghs's Avatar
Baghs
I just purchased a 99 about two months ago. A few weeks and few thousand miles later I started hearing a really painful rattle...right behind the dash..only happened under load when in drive. I could never re-produce it while in a position to find it. I took it to the dealer on Monday and they checked it out..the noise doesn't happen all the time so naturally they didn't hear it and I travel alot so I couldn't be there to drive it for them. However, they did find that my o2 sensors were not hooked up (meaning not in the exhaust). They were out and resting on the exhaust with empty o2 extensions in their place. Creating a exhaust leak. I had a couple of other exhaust leaks also. I had them repair this and will pick up the car tomorrow. I hope that was my "rattle" noise. God let it have been my rattle noise. And, can someone please tell me why in the world anyone would leave the o2 sensors off???? That concerns me. It's such a strange thing to do.
Old Jan 17, 2008 | 01:23 AM
Fred Linden's Avatar
Fred Linden
Default Rattle
I had what I thought was a rattle coming from the dash in my 02 vert. Finally foung the source was the hood on the passenger side was not resting against the rubber stop up by the windshield. Raised the rubber stop up about one turn and presto, no rattle.
Old Jan 17, 2008 | 08:00 AM
9secondflat's Avatar
9secondflat
solution turn the radio up
Old Jan 17, 2008 | 12:16 PM
corvettebob1's Avatar
corvettebob1
Don't laugh just go and try this, next time it's cold and the rattle is present.
Reach up and grab your driver sunvisor and hold the mirror door down.
I think you will be suprised, I had my 98 coupe into the dealer more time then I could count for this.
They never found the problem because they always checked it after it sat inside long enough to warm up the plastic.
Old Jan 17, 2008 | 05:39 PM
red88L98convert
well it's definately inside the car. and it happens whether its hot, cold, warm, freezing....don't matter. the best way to describe it is that it sounds similar to the fob hitting against the dash...and NO that isn't it. also, the hvac doesn't blow hot or warm air. i'm thinking it has something to do with the vents towards the fire wall??
it is as annoying as my ex.
Old Jan 17, 2008 | 07:48 PM
flynbya2's Avatar
flynbya2
I have to agree about the hood rattle,it sounded like it was inside too.A minor adjustment fixed that rattle.
Then I also remembered,that at one point,I had developed a rattle that turned out to be just the visor not being firmly in the mount.I know it sounds kind of dumb,but it projected and sounded like it was in the dash.It troubled me for a little while
Probably not your issue,but since many may look here that have a rattle,....well, why not?
So,I'm 2 down,1 to go
Old Jan 17, 2008 | 07:53 PM
red88L98convert
hood is tight, visor has already been tightened. i'm thinking i have to pull dash apart to fix heating issue which will probably be the rattle...
Old Jan 17, 2008 | 08:33 PM
flynbya2's Avatar
flynbya2
Looked in manual,here is what I found pertaining to rattles in dash:
Rattle from center of instument panel(I/P)
Possible cause
The I/P pad attaching screws at center defroster vent are loose
Correction
1. Road test while applying pressure to the vent area of the I/P pad and listen for the noise to stop
2.Remove the center defroster vent and tighten the I/P pad attachment screws
3. Reinstall vent
Rattle from the forward outer edge of the Instrument panel pad
Possible Cause
Not enough insulator foam between the I/P and the pad.
Correction
1. Road test and apply hand pressure to the forward edge of the instument panel pad to find the location of the rattle.
2.Remove instrument panel pad.
3. Install added insulation at the point of rattle to the underside of the pad.
May not be your cause,but I hope it may help in some way.
Old Feb 19, 2008 | 11:27 PM
DIAMOND DAVE's Avatar
DIAMOND DAVE
Any help?
Well I am with you all on squeaks but rattles is something else. Took my last 3 Vettes in for damn dash rattle and they could not find it on none of them. My first suggestion is when you hear it, especially on autos is put light pressure on your release button on the shifter and I think that is where 90% of the damn rattles is coming from. Even my 08 has the same noise on a somewhat rough surfaced road. It does sound like it is coming from the dash area, but I can just about assure it is not. Just a slight pressure on the shift release and it will dissappear
To In Dash Rattle......uuugh!!
