Check your Battery!..to avoid this...
Old Nov 29, 2001 | 06:58 PM
dougatl's Avatar
dougatl
Default Check your Battery!..to avoid this...
Quite an experience indeed. Last night, my near 3 year old C 5 was rendered inoperable. Got in the car, started it up,
and the DIC started flashing every conceivable message imaginable: service vehicle soon, reduced engine power, etc etc. Bing, Bong,
nothing I could do to stop it. I shut the car down moments later and then all hell broke loose. In a nutshell, the car wouldn't start. No lights,
radio, nothing, zip, not even the trunk lid button would work. It reminded me of a Pontiac GTO I had moons ago with a "kill switch" ...no juice, no fuel supply.
Got towed to a dealer and this afternoon found out that it was a bad battery cell that was the culprit. Apparently, the techies said
when the battery reaches 3 years old, sometimes they start to go bad, and the reduced voltage can cause quite a problem with the
onboard computer. You can say that again! ..Just a heads up...if your battery has some age on it.
Paul [IMG][/IMG]
[Modified by dougatl, 4:58 PM 11/29/2001]
Old Nov 29, 2001 | 11:00 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Check your Battery!..to avoid this... (dougatl)
My original battery on lasted 4 months! Then I went for the Die Hard.
Old Nov 29, 2001 | 11:23 PM
Paradigm's Avatar
Paradigm
Default Re: Check your Battery!..to avoid this... (wallstAL)
Origianl battery sucks
Old Nov 29, 2001 | 11:32 PM
ambitin's Avatar
ambitin
Default Re: Check your Battery!..to avoid this... ('98 Six Speed)
Sigh.
PROBLEM:
SOLUTION:
Lates,
Justin
Old Nov 30, 2001 | 12:40 AM
Dave68's Avatar
Dave68
Default Re: Check your Battery!..to avoid this... (ambitin)
ANSWER:
See:
http://www.acdelco.com/html/pi_batt_plat_comp.htm
[Modified by Dave68, 10:42 PM 11/29/2001]
Old Nov 30, 2001 | 08:57 AM
Tom/99's Avatar
Tom/99
I am happy with Delco batterys. After sitting two weeks, the temperature in the mid 30's, my 8 year old Delco battery had no problems starting my car.
Old Nov 30, 2001 | 09:06 AM
shftn6's Avatar
shftn6
Did the dealer just drop a new battery in and then everything was ok with the car/computer or did the bad battery cause additional damage?
Old Nov 30, 2001 | 09:20 AM
TestAmenTC5's Avatar
TestAmenTC5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Check your Battery!..to avoid this... (shftn6)
The same thing happened to my wifes '98 and it was right at 3 years old. I did get the car started with a jump start and drove it straight home. Put in a new battery and all was well. No additional damage to anything.
Old Nov 30, 2001 | 11:00 AM
6699's Avatar
6699
Hi,
Had my battery switched for an Optima within a week after I took delivery!
Don´t take a chance, go out and get an Optima today!!!!!!
Mikael
Old Nov 30, 2001 | 11:13 AM
CliffB-99's Avatar
CliffB-99
Default Re: Check your Battery!..to avoid this... (6699)
Another satisfied OPTIMA customer here.
Old Nov 30, 2001 | 11:38 AM
jeffh355's Avatar
jeffh355
The first thing I do when I buy any car is the Optima battery!
Old Nov 30, 2001 | 12:25 PM
EDC's Avatar
EDC
Great message.
I and many others have had the same problem.
EDC
Old Nov 30, 2001 | 12:40 PM
MDT's Avatar
MDT
ambitin,
If a picture is worth a thousand words, then you just presented a very nice 3000 word critque. :) Thanks.
Good luckl.
Mark
Old Nov 30, 2001 | 01:26 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: Check your Battery!..to avoid this... (MDT)
...but the acid damage can be irrepairable. Just look at all the wires that get melted. I think everyone should take a look there under the + terminal.
Mine leaked too.
George
Old Nov 30, 2001 | 08:12 PM
bassfisher's Avatar
bassfisher
Default Re: Check your Battery!..to avoid this... (Speed-Racer)
Don't take a chance on the battery acid leak from the Delco POS - get an Optima and stop worrying.
To Check your Battery!..to avoid this...
