fuel line fitting question
Old Nov 29, 2001 | 10:35 PM
70 LS1's Avatar
70 LS1
Default fuel line fitting question
I am getting ready to build a fuel line for my 99 LS1. I am having a hard time finding stock style fittings that will connect to the fuel filter/ pressure regulator and to the fuel rail. Does anyone know where I can find some of these quick disconnect fittings?
Old Nov 30, 2001 | 01:38 AM
davidfarmer's Avatar
davidfarmer
Default Re: fuel line fitting question (70 LS1)
You will probably have to have someone "tig" weld a factory piece to the style fitting you wish to use. That is what I had to do to run my Quartermaster clutch with the OEM slave cylinder.
GM isn't too good at using easy-to-swap parts.
Dave
