anyone replace negative battery cable?
Old Jan 20, 2008 | 12:52 PM
Kale's Avatar
Kale
Default anyone replace negative battery cable?
The connector on mine no longer tightens up enough. I don't want to put an aftermarket connector on it.
Are all the access points for the battery cable easily accessible, or is it going to be a job and a half?
Old Jan 20, 2008 | 12:54 PM
lucky131969's Avatar
lucky131969
So is the connector stripped, or is the battery stripped?
Old Jan 20, 2008 | 01:09 PM
Kale's Avatar
Kale
I'm not sure. The connector, at its tightest point, is still loose on the battery.
It could be the terminal is worn down past the point where the connector stops getting tight... or it could be the nut/threads are jammed on the battery cable.
Old Jan 20, 2008 | 02:04 PM
lucky131969
Ok....what does it look like? Compare it side by side with the positive cable. Is it corroded?
Old Jan 20, 2008 | 02:10 PM
Kale's Avatar
Kale
it looks ok, but the sides are scraped up more than positive.
Old Jan 20, 2008 | 02:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The terminal bolt is steel and the battery terminal is made of lead. If the battery terminal threads are damaged,you may be able to remove the bolt from the cable end and find a longer bolt to engage the undamaged threads. Just check the depth of the hole in the battery terminal and make sure you don't get one too long.
If you really do need to replace the NEG cable, you have to jack the front of the car, remove the cable from the passengers side of the block down near the starter and the small pig tail frame ground on the frame next to the battery:
Old Jan 20, 2008 | 02:32 PM
Kale's Avatar
Kale
Mine is this style, unfortunately:
Old Jan 20, 2008 | 03:01 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Your cable apears to be some sort of aftermarket jobby.
Have you checked any of the local auto parts store for replacement, like advance auto or pep boys ?
Old Jan 20, 2008 | 03:04 PM
Kale's Avatar
Kale
Nah, that's stock for 2004 Vettes. (maybe 2003+ iirc)
I cant just replace the nut because it has some bevel on the bottom of it.
Its supposed to squeeze the terminal, but it no longer does that very well.
Old Jan 20, 2008 | 03:41 PM
dudleyd's Avatar
dudleyd
What a coincidence, that’s why I love this forum. I replaced my battery yesterday and when I tightened down the Neg. terminal the bolt was fully tight but the cable was still lose. I have a 99 which uses the side terminal battery like B.C. pictured in his post. I ran out of time yesterday to investigate the problem but was just getting ready to go out and pull the battery to see if I can figure out what’s going on. What I know right now is the bolt on the terminal looks fine so I’m thinking the battery terminal is not taped fully or defective in some other way. I’m going to be PO if its the battery as I got it at Napa and there closed today. This was one of these new heavy duty dry battery’s, no plates and acid but coils. I think Orbit is the manufacture, freaking expensive, $180. I’ll post up my findings in a little while.
DD
Old Jan 20, 2008 | 04:02 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sorry,,I ASSUMED you had the common place older battery terminals. See if the dealer has a replacement terminal end. From the picture it looks like it just bolts on to the wire eyelet as a replaceable unit. Call/contact Gene Cully, www.gmpartshouse.com and see what he has for replacement.
Old Jan 20, 2008 | 04:22 PM
lucky131969
I wonder why gm did not stay with the old type top post design (clamp style). I wonder if a replacement like this would work in the connector housing ?:
http://www.partsamerica.com/ProductD...egoryCode=3019
Should stay nice and tight.
Old Jan 20, 2008 | 04:37 PM
Kale's Avatar
Kale
gmpartshouse has the whole cable, so we'll see.
Old Jan 20, 2008 | 06:41 PM
lucky131969
You don't need the whole cable.
Old Jan 20, 2008 | 07:27 PM
thetaxman's Avatar
thetaxman
use a copper shim
Old Feb 11, 2014 | 09:39 PM
Mike the 98 vetteman's Avatar
Default copper wire
Originally Posted by thetaxman
use a copper shim
I used a single strand 3-4" copper wire wrapped around neg bat terminal bolt (not even very well) then screwed on and presto a tight fit. Been working for months.
Old Feb 12, 2014 | 12:25 AM
LoneStarFRC's Avatar
LoneStarFRC
Betcha he got his problem solved 6 years ago.
To anyone replace negative battery cable?
