theaft deterant relay
Old Jan 25, 2008 | 11:07 PM
99vet's Avatar
99vet
St. Jude Donor '12-'13-'14
Default theaft deterant relay
Where does it go
Old Jan 25, 2008 | 11:13 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You should give us a lot more information since we cannot figure out what you are asking. Where does it go??? Is your car running, dead or intermittent?...some other issue?
Old Jan 25, 2008 | 11:44 PM
99vet's Avatar
99vet
The car at times will not turn over and I have to wait 3 minutes and it usauly start after. I bought the theaft deterant relay but can not locate where it goes....Thanks for asking.
Old Jan 26, 2008 | 12:11 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bud,,,,I feel your pain! Back in the day my 98 had a bad TDR. I played hell finding it. Here you go:
Look on the fire wall just above the BCM (big silver box). There are TWO relays. The one with FOUR wires RED, PURPLE, yellow and yellow/black stripe is the TDR.
If you change out the TDR and still have the issue, you most likely have a bad starter solenoid (just like me). I have a 3 foot metal rod in my trunk so I can bang the starter when she refuses to crank!
Bill
Old Jan 26, 2008 | 12:23 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Bill
Did I hear that right??? THe master of Electrical problems banging on the starter when it refuses to crank???
Old Jan 26, 2008 | 01:18 AM
dgrant3830's Avatar
dgrant3830
Hey, if it works, it works. I use to have a VW Scirocco years ago and the alternator started wearing out due to worn brushes. I would go out there and whack it a couple of times with my hand and it would come back to life!
Old Jan 26, 2008 | 08:11 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yea, it comes down to only wanting to pull the engine apart ONCE! I have some MAJOR mods ready to install and the passengers header needs to come out to have a wide band bung welded in place. So,,,until I do this Mod,,,work arounds are welcome and highly used!
Hey,,,,at least I figured it out and have a good workaround! Your jaw is going to drop when I disassemble the solenoid and starter and rebuild it!
BC
Old Jan 26, 2008 | 08:27 AM
Oldvetter's Avatar
Oldvetter
Bill,
That is pretty ironic and kinda funny !
Hey Bill, thanks for all the help you have given everyone, you are truly THE MASTER OF ELECTRIC PROBLEMS !
Oldvetter
Old Jan 26, 2008 | 01:19 PM
99vet's Avatar
99vet
Starter silenoid huuuuuuum. I'll have to bang on it next time. Thanks for the Pic./help.
Old Jan 26, 2008 | 03:36 PM
99vet's Avatar
99vet
The relay is in. Went for a ride and the "Security light on the Cluster comes on about 30 seconds after the car is on. Had this happen before replacing the TDR. The car does start so far every time.
Old Jan 26, 2008 | 04:38 PM
BitViper's Avatar
BitViper
Our cars have TDR? really
How is it set etc...
Old Jan 26, 2008 | 05:25 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here ya go!
To theaft deterant relay
