Lights out!
Old Jan 27, 2008 | 09:17 AM
Kwikz28's Avatar
Kwikz28
Default Lights out!
Need help trying to figure out why my dash lights along with my turn signals won't work in my 01 Z. They will come on, just not all the time. This also has affected my rear tail lights. No dash, no tails lights. However my brake lights will come on when I hit the pedal and my headlights work fine. Fuses and Bulbs all seem good due to everything will work once the car has been on for 15min or more. Whats the problem and how do I fix?
Thanks.
Old Nov 3, 2008 | 01:05 PM
astoner3's Avatar
astoner3
Cruising
My C5 does the same thing!
Old Nov 3, 2008 | 03:16 PM
illusiveC5's Avatar
illusiveC5
8th Gear
my blinkers are doing the same exact thing.. sometimes they work perfectly, and other times i get no blinkers. They don't show up in the heads-up display or in dash.. shortage in connection maybe? so it's working sometimes but then shorts out and stops?? it's like a guessing game whenever I turn the c5 on if they are going to work or not lol..
Old Nov 3, 2008 | 04:47 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks.
Answers is Fuse #6 under passenger footwell. Donations appreciated.
Old Nov 3, 2008 | 07:37 PM
lucky131969's Avatar
lucky131969
Good call..that will affect instrumentation and brake lights for sure.
Old Nov 3, 2008 | 07:39 PM
fst85vtt's Avatar
fst85vtt
My vote is the multi switch
Old Nov 3, 2008 | 08:34 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Hey Andy,
It's the fuse. Been there a few times. If it were a blinker or certain other items it could be the stalk.
Old Dec 22, 2008 | 07:49 PM
vettesrgt8's Avatar
vettesrgt8
From what I've been reading if the dash and tail lights are out then it's probably the light switch. Here is the repair for it although some think just replace the switch.
http://forums.corvetteforum.com/c5-t...f-replace.html
I would like to know what causes the tail lights out only. I have dash, head lights, turn signals, brake, and hazard lights. Just no tail lights or lights on with head lights or running lights.
Anyone know what it might be. The ground is shared so it shouldn't be that.
Old Dec 23, 2008 | 09:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Try fuse #6 passenger footwell.
Old Dec 23, 2008 | 09:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yea, the fuse is easy to check and replace but, ,,the multifunction swich is most likely the issue. Rebuild that puppy!
BC
Old Dec 23, 2008 | 10:05 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
BC
But it's worth a try.
Old Dec 24, 2008 | 04:28 AM
209TIME!!!'s Avatar
209TIME!!!
my low beams dont work all the time,have any of you ever had that problem???
high beams work all the time with no problem, can someone help please.
thanks for any good suggestions
Old Dec 24, 2008 | 08:49 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Do the light pop up all of the time ? If they do pop up all of the time, more than likely it a bad column stalk switch.
About $200 from the dealer or check ebay.
Old Dec 24, 2008 | 09:08 PM
209TIME!!!'s Avatar
209TIME!!!
yes sir they pop up but the lights will not come on,if i sit there for a little while they will just turn on.
now when they dont come on, and i want to put them back down i have to turn on the high beams first then turn them off and the lights will turn off and go down
wow i dont know what to do!!!.........
Old Dec 25, 2008 | 08:28 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Do you have HID's installed on the low beam circuit ?
Old Dec 27, 2008 | 12:30 PM
209TIME!!!'s Avatar
209TIME!!!
no HID'S everything is stock
Old Dec 27, 2008 | 09:43 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sonds like some bad contacts in the column stalk.
To Lights out!
