removing coolant lines
Old Jan 27, 2008 | 03:18 PM
Lancer033's Avatar
Lancer033
Default removing coolant lines
Is there some trick to getting old coolant lines off. I started swapping mine out last night and got about half way done and the only thing that worked for me was cutting them off. After 5 years, it feels like they're glued on.
Old Jan 27, 2008 | 04:42 PM
thetaxman's Avatar
thetaxman
I made a tool
I took a small screwdriver, heated it and bent it at a 90 degree angle.
Then ground it smaller so I could slide it between the hose anf the fitting.
I've seen then on sale before but don't know whay they are called.
It was easier to just take a junk screwdriver and make one.
Old Jan 27, 2008 | 04:46 PM
BowTieRocket's Avatar
BowTieRocket
Originally Posted by thetaxman
I made a tool
Great idea!
I've used screwdrivers with a little grinding to round the edges, but hadn't thought of bending one. Sounds like a good use for a cheap screwdriver!
Old Jan 27, 2008 | 04:54 PM
thetaxman's Avatar
thetaxman
Originally Posted by BowTieRocket
Great idea!
Thanks, I make special tools all the time.
Sometimes I copy, somrtimes I invent.
TIP : When you heat the screwdriver , put it in a vise handle down, or you could melt the handle.
To removing coolant lines
