Code P1416
Old Jan 27, 2008 | 07:16 PM
bobdobb's Avatar
bobdobb
Default Code P1416
Air system bank two. Can anyone enlightem me?
Old Jan 27, 2008 | 07:22 PM
ruffian's Avatar
ruffian
I've had this a couple times when it first got cold back in December. Searched forum and found recommendation to disconnect hose near the manifold and send a bunch of intake cleaner (carb cleaner) into the tube to hopefully flood the check valve. Apparently the valves will stick partially open and will cause a check of the AIR system to fail.
I couldn't figure out how these guys got enough carb cleaner in shooting from down low against gravity and a couple of bends, so I took some vacuum hose and wet it with wd40 and stuff it up the AIR hose until it wouldn't go any further, then I sprayed the carb cleaner. Worked. Haven't had another problem with the P1416 code since...
bob
Old Jan 28, 2008 | 05:23 PM
bobdobb's Avatar
bobdobb
Found an air leak. Fixed. Thanks!
Old Jan 28, 2008 | 06:06 PM
briann510's Avatar
briann510
Where exactly was the air leak??
Old Jan 29, 2008 | 03:16 PM
bobdobb's Avatar
bobdobb
Rear bolt had backed out on passanger side exhaust manifold air line.
To Code P1416
